CTS-V Suspension Tuning - Page 2
Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 16 to 30 of 78
Like Tree7Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, CTS-V Suspension Tuning in Cadillac CTS-V Series Forum - 2004 - 2007; Guess what time it is? Swift Z70-203-120 springs (672 in-lbs) and Swift Z60-228-160 springs (896 in-lbs) Banski Motorsports Prototype Spherical ...
  1. #16
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: CTS-V Suspension Tuning
    Banski Motorsports Prototype Spherical CTS-V RSMs
  2. #17
    BradCTSV is offline Cadillac Owners Fanatic
    Automobile(s): Cadillac 2005 CTS-V
    May 2007
    114
    Since I'm lucky enough to live near Sonoma Raceway, CA, I had Performance Shock dyno my LG Motorsport/Bilstein coilovers. The rebound was significantly increased on both front and rear shocks--the difference on the road is HUGE!! On top of that I ordered CCW SP600's (19x8.5 and 9.5) in satin black with Hankook RS3's (245/40 and 275/35).
  3. #18
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by BradCTSV View Post
    I thought I was the only one that liked Hankook rs3 tires on my cars. It seems like everyone uses Michelin pilots on their V and vettes
  5. #19
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,857
    FuzzyLogic - Please contact CF Admin about becoming an Authorized Vendor.
  6. #20
    Mar 2011
    2,045
    Quote Originally Posted by Submariner409 View Post
    I'm not selling anything (I work for an unrelated military contractor), and I receive zero compensation for any of this. This is a suspension tuning thread. Technical discussion.
    greengator likes this.
  7. #21
    Feb 2006
    55,857
    Sorry for the mistake - several posts in the forum have been reported as advertising spam, have been analyzed, and you're clean. Read my PM. Thanks for the comeback.
    Also, note that the other thread on suspension arms is back in business.
  8. #22
    Mar 2011
    2,045
    That's amusing. I take it Creative Steel marked my posts as advertising spam?
  9. #23
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    I am in the same boat, where i am CF everywhere, except no roll cage. i have to check my spring rating, but i think i went with a 500/550, 12" front and 10" rear lengths.
    I kept the rear setup pretty much like stock where the spring and shock are separate, just so i may have the widest tire possible.
    I have from 450-650 in Hyperco spring ratings and in 8-12" length. So i am pretty much covered in all angles...
    I dont think with a good spring brand you will need to go any higher than 600 for you have the chance to adjust the shocks more precisely.
  10. #24
    Mar 2011
    2,045
    Quote Originally Posted by Naf View Post
    I don't think you understand that springs provide constant support (i.e.: roll resistance) that shocks can never provide because they have valves and will "leak" oil past those valves during sustained G-loading.
  11. #25
    Mar 2011
    2,045
    For those of you following along:
    I had just enough time yesterday to install the rear, 896 in-lb springs (front springs are still stock). Since adding more spring effectively increases compression dampening but requires more rebound to control, I instinctively set compression dampening to minimum and added one click of rebound dampening. Holy s**t the car feels good-- not only is it much faster during transitions, it's COMFORTABLE! This kind of ride quality would have been flat-out impossible with FG2s and the Ground Control kit.
    The net effect is that the rear feels only about 10% stiffer under bump loads, but on turns, the body confidently follows the front of the car and refuses to roll.
    In summary, I unequivocally recommend that all KW Variant 3 owners get a pair of 9", 60mm, 160 N-m springs and a pair of 65mm thrust sheets. It'll be $200 very well spent.
  12. #26
    mackey is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Black
    Sep 2012
    172
    noted
    experiencing front end push >1G so if this cures that as well as aformentioned plushness and roll resistance, then i'm game as that's exactly what i'm looking for.
  13. #27
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    These are not the Swift Z60-228-140 (9" length, 784 in-lbs) that you recommended to me? Curious why you chose to run different before I throw my order in.
  14. #28
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    Fuzzy,
    Its great you are experimenting with your spring tension.
    I am chatting with my suspension guy and working it out so i can be happy on the track and on the street
  15. #29
    Mar 2011
    2,045
    Quote Originally Posted by mackey View Post
    At more than 1.0G, you're going to be fighting a lot of things. I never said that the ride was plush. It's about 10% stiffer than the KW Variant 3 with KW's recommended compression dampening setting. However, it's more comfortable because the car isn't pitching and the rear isn't rolling out from behind the front of the car.
    It sounds like you're assuming that your front-end push is merely due to having lower roll resistance in the rear. Please note that this issue will be exacerbated if you're on the gas through the turn, since you'll be transferring even more load to the rear. I would also look at your alignment. Make sure you zero out your toe in the front, or maybe even set it to 0.05 degrees of positive toe per wheel (0.10 degree total). Whatever you decide, add at 0.02 degree of negative toe to the passenger side front wheel to prevent the car from wanting to drift right on roads with excessive crown.
    Quote Originally Posted by Manofmetal01 View Post
    Could you refresh my memory? I don't remember when that was. I definitely recommended those springs for the guys running Ground Control kits.
    To be frank, I took a risk (even though I believed my calculations) with the 896 in-lb rear springs (versus the 784 in-lb springs), because I didn't know how wide the compression valving on the KW Variant 3 opened, or how viscous the oil in the shocks was. If I recommended the 784 in-lb springs to you, it was because that was the "safe" option. First, 784 in-lb springs would have hugely reduced pitch on your car and fixed the lack of roll resistance in the rear, and second, the risk of you complaining that the ride was harsh was significantly less.
    But as it turned out, with the rear shocks set to minimum compression (full open), the rear end's dynamic compression only increased by about 10%. It's comparable to a FG2/GC/600 in-lb spring. Knowing that, I can recommend the 896 in-lb springs for anyone with a KW Variant 3 kit. Your front/rear bias with the stock front springs is going to be -15%, which is smack in the middle of the 10-20% sweet spot.
  16. #30
    barrok69's Avatar
    barrok69 is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V Maggied
    Mar 2012
    Michigan
    271
    Quote Originally Posted by RyRidesMotoX View Post
    Not to threadjack, but for daily driver summer tires, the PSS's are hard to beat. RS3's are awesome on dry, but terrible in the rain. My next set of tires is going to be Bridgestone RE-11's due to Michelin not making the width/aspect ratio I'm looking for in their PSS lineup.
  17. Remove Advertisements
