Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 41
Thread: Tuner specced me a cam-- what'll she make?
  1. #16
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Tuner specced me a cam-- what'll she make?
    You will absolutely 1000% need to swap out your stock squeeze tube. That will be significantly holding you back once the cam is in.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  2. #17
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by trukk View Post
    -Chris
    Stop talking dirty.
  3. #18
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    -Chris
    Gonna pick up a silicone 4" elbow, 4" pipe, 4" to 3" reducer and clamps tomorrow.
  4. #19
    Apr 2012
    Seattle, WA
    731
    -Chris
  5. #20
    Mar 2011
    2,045
    Quote Originally Posted by HAMSTAR View Post
    I was going to say...if you're going in on that, you might as well do carbon fiber. I'm still planning on dumping all three of my intake tube designs and doing a solid 4.0" ID tube.
  6. #21
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by FuzzyLogic View Post
    WRT CF, it's a matter if return on investment. The air moves through the pipe so fast that it isn't affected by the heat of the pipe. The temp sensor is another story, and I will eventually get to sensor relocate to the filter, as you have done.
  7. #22
    odthetruth's Avatar
    odthetruth is offline Moderator
    Feb 2010
    NYC
    4,969
    Install and dyno will be next week. So, let's have some guesses on max TQ and HP? Where in the rev band do you think she'll peak HP and TQ?
    413rwhp \ 376rwtq
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  8. #23
    Mar 2011
    2,045
    I'm not talking about the heat rise (which is typically between 0.7 - 1.3 degrees F). I'm talking about the structural strength. Silicone tubing is very pliable and will not hold up to forced induction. Carbon fiber tubing is about 50% stronger than aluminum and 75% of the weight.
  9. #24
    Apr 2012
    Seattle, WA
    731
    Oh yeah I'm going with Al. Can't justify the cost of carbon fiber.
  10. #25
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    49
    291
    With the short nature of the run and the complex shapes (two rather awkward turns) necessary for the Eforce on our cars I am not sure rigidity will be an issue. I'm not even sure that you will be able to utilize a CF tube on the intake because of mounting difficulties. I would hold off on the CF until you get it put together with your existing silicone tubes.
  11. #26
    Mar 2011
    2,045
    Quote Originally Posted by sssnake View Post
    Definitely the smart approach.
  12. #27
    Apr 2012
    Seattle, WA
    731
    Ok, I have the new 4" tube and parts. What's the best way to connect te stock 4" PCV tube to the new DIY aluminum pipe? I have a mightymouse catch can on order but probably won't get it till after the tune and install. I would like to just use the 1/4" ID OEM tube.
    I know I need a nipple of some sort. What should I ask for at Home Depot? Also, what's te best way to fix/adhere the nipple to the pipe?
    Thanks!
  13. #28
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    I used something similar to this:
    http://www.beveragefactory.com/draft...FYed4AodgUUAHA
    but it was a 90 degree bent one.
    Sealed around it from the outside with RTV gasket maker.
    [2006 CTS-V]
  14. #29
    Apr 2012
    Seattle, WA
    731
    Here's a quick vid I took to show off the idle. I pop the hood, too, so you can see the valvetrain is quiet as a mouse. I did a little driving today, and this cam is deceptively smooth. I can break traction in third gear now just by stomping it-- that is definitely new. It's also obvious I'm going to have to relearn how to drive it somewhat, since the power band has changed so significantly. We'll find out exactly how next week.
    2006 CTS-V LS2 cammed idle vid - YouTube
    You may notice the stock intake tube is still on there. That's because we ran out of time to work on the DIY intake. We're going to press it into a slight oval shape where it passes the PS pulley. Hopefully it will pick up some more with the wider intake tube.
    Oh yeah, and my engine bay, not to mention my car, is dirty as ****. Just got it back from the shop. Gonna take it for a bath later.
  15. #30
    BigDaddy-V is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V 04 LS6
    Mar 2013
    Wylie, TX
    412
    That sounds pretty quiet with that size cam! I am sure the WOT isn't that quiet but look forward to some further videos and sound clips!
    BDV
  • You may not post replies
