Anyone seen this before? Broken oil pickup tube on 2006 V
Results 1 to 7 of 7
2004-2007 Cadillac CTS-V Performance Mods Discussion, Anyone seen this before? Broken oil pickup tube on 2006 V in Cadillac CTS-V Series Forum - 2004 - 2007; My V probably has more miles on it than most with 155k, but I have never even heard of one ...
    iambigperm is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-V, 2003 Escalade EXT
    Aug 2012
    Las Vegas, NV
    38
    25
    My V probably has more miles on it than most with 155k, but I have never even heard of one of these breaking like this. When starting the car Saturday morning it has zero oil pressure. I immediately turned it off and put a mechanical gauge on it... 0 psi. I went through this once before when the oil pressure relief valve stuck about 6 months ago. I put a new pump on and it has been good ever since.
    Given my previous experience I thought there had to be something sticking that valve open again. I towed it to my shop and removed the pump. This time the valve was shut and looked good(as did the pickup tube o-ring). Next I pulled the pan found that the bracket on the strainer end of the pickup tube had broke off. Without that intact I'm sure it was just sucking against the bottom of the oil pan. Aside from a cam swap 5,000 miles ago, this engine has never been apart. Anyone seen this before? I googled the crap out of this and didn't find any instances on any lsx based vehicles.
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Re: Anyone seen this before? Broken oil pickup tube on 2006 V
    I never seen, nor heard of it. Nice catch though, many of us might have ruined the engine looking for the problem while assuming it was a bad gauge or the like.
    R07.2 is offline Cadillac Owners Member
    Automobile(s): CTS V
    Apr 2013
    Mine was broken in the same place on '05 with 116k. No oil pressure problems though. Found it after I pulled the engine for swap.
    Aug 2012
    Las Vegas, NV
    38
    25
    I pulled the number 8 rod cap and the bearing still looked like new. I think I might have got lucky in that regard. It probably only ran 15 seconds or so. If these didn't put the low-oil pressure message on the radio/nav screen it would have been a goner for sure. Pulling the pan in the car is a PITA. I used an engine support bar so I could raise the engine while hanging the cradle down.
    Quote Originally Posted by R07.2 View Post
    That did cross my mind... What if the broken bracket wasn't actually causing the problem.. I didn't see anything else so my fingers are crossed that a new tube fixes it.
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,361
    Never heard of this before. Keep us updated please.
    Aug 2012
    Las Vegas, NV
    38
    25
    New pickup tube arrives tomorrow. With any luck I'll be back to burnouts tomorrow night.
    Aug 2012
    Las Vegas, NV
    38
    25
    I finished installing the new pickup tube tonight and oil pressure is back to normal. Runs as good as ever and hopefully no permanent damage was done. I'll cut the oil filter open at the next oil change to see if there are any surprises. I would recommend to anyone who has their pan off to throw a new pickup tube in. This could have really sucked.
  10. Remove Advertisements
