Water Pump suggestions? small leak on stock pump
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V Performance Mods Discussion, Water Pump suggestions? small leak on stock pump in Cadillac CTS-V Series Forum - 2004 - 2007; I have a small leak from my water pump, currently waiting for Heads/Cam, Eforce to come so I thought I ...
    Johnson's Avatar
    Johnson is offline Cadillac Owners Member
    Automobile(s): 2011 CTS-V Sedan - 2005 CTS-V - 2000 Trans Am WS6
    Mar 2010
    Vancouver, BC
    81
    I have a small leak from my water pump, currently waiting for Heads/Cam, Eforce to come so I thought I would do all the changes at the same time. Wanting to know best option for replacement/aftermarket water pump or best to stay with stock? car is a daily driver that see's some track time. Thanks
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,179
    Re: Water Pump suggestions? small leak on stock pump
    The OEM is part number 89018052 (replaces part number 89017592) with an MRSP of $397.42. It is available from online suppliers at less ($195 - $230 before shipping, handling, or taxes, based on a short search).
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Have you checked the gaskets to see if it's not a problem with the pump?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,179
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Just go with an OEM pump. They make it about 80 or more, which is good for a high performance vehicle. High flow pumps can flow too fast, not giving coolant enough time in the radiator to cool down.
    Also, people will tell you it may be the gaskets, but te only way to tell is to replace the gaskets, at which point you already have already taken the car apart and put it back together. Do you really want to do tht again if you find it's still leaking. A new water pump is cheap insurance either way.
  8. Remove Advertisements
