front end too low with Ground Control, need opinions please - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 40 of 40
2004-2007 Cadillac CTS-V Performance Mods Discussion, front end too low with Ground Control, need opinions please in Cadillac CTS-V Series Forum - 2004 - 2007; Yes, you're over thinking this. Unless someone modified OEM struts to reduce their range of travel (highly unlikely), those struts ...
  1. #31
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,467
    Re: front end too low with Ground Control, need opinions please
    Yes, you're over thinking this. Unless someone modified OEM struts to reduce their range of travel (highly unlikely), those struts are designed to normally be sitting 1.5-2" higher than where yours are sitting now. Raising the spring perch will raise the car.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  2. #32
    Chirpin4th is offline Cadillac Owners Member
    Apr 2013
    san antonio
    35
    48
    I guess I'll find out for sure when they get here. It just seems funny that I can compress the spring with no load on the front suspension?
  3. #33
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    If your endlinks are set correctly, you will have some preload on the springs.
  5. #34
    Apr 2013
    san antonio
    35
    48
    Yeah, you guys are right. If the strut itself had been any longer I wouldn't have been able to get it back in place by myself. I stuck a 1/2" breaker bar in the center of the wheel hub and stood on it, while working the strut assembly back in.
  6. #35
    Apr 2013
    san antonio
    35
    48
    Just saying thanks! Those spacers worked perfect, I now have more than enough adjustment on the height. And I got some good practice at taking them apart. I'll need it since I'm pretty sure both front struts are on their way out. Pretty sure I could do 25 min a corner, with no air. Not too bad for a rooky.
    Btw, that was my first time ordering from JEGS. They are pretty awesome. They are open real late, (maybe 24 hrs) and when you make an order you get a tracking number though email. And my parts where here in 5 days.
  7. #36
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Yeah, Jegs. I placed an order for a set of Mickey Thompsons to mount on Z06 wheels for my V2. They had the best price and gave me a confirmation number.
    At the end of the week, still no MTs. Called back and they had no record. Gave them my tracking number. Still no record. My card was never charged but I was deeply disturbed that my order became vaporware.
    I never reordered or ordered from anywhere else.
  8. #37
    Apr 2013
    san antonio
    35
    48
    That's no good. I ordered a trans mount from rev shift 2 days before I ordered the spacers. I hope they
    are on their way.
  9. #38
    Apr 2013
    san antonio
    35
    48
    Rev shift sent me a tracking number... After getting underneath the car for an oil change I noticed that it already has a poly trans mount. I assumed it didn't because I have to do the 4th to reverse trick to get it to engage smoothly. I'm also having a hard time downshifting to 3rd. I wonder what could be causing this?
  10. #39
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Quote Originally Posted by Chirpin4th View Post
    The first item on the troubleshooting chart for any gear shifting problem is to flush and bleed the clutch hydraulic system.
  11. #40
    Apr 2013
    san antonio
    35
    48
    thanks! when I bought it the reservoir was empty. I have filled it 3 times, now it stays full. I will do a flush/fill and see what happens. Time to bust out the mity-vac. I should prolly install in the ls7 clutch/flywheel that's been sitting out of the car for the past 3-4 years.
  12. Remove Advertisements
