Quick KW V3 Installation Question
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V Performance Mods Discussion, Quick KW V3 Installation Question in Cadillac CTS-V Series Forum - 2004 - 2007; Hey, the KW Variant 3 installation instructions seemed sparse with respect to the rear springs. Is it true that there's ...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Hey, the KW Variant 3 installation instructions seemed sparse with respect to the rear springs. Is it true that there's no mounting attachment for the threaded part of the rear spring mount? Spring tension is all that holds that thing up there?
    I'm coming from a Ground Control setup and still have some of the original pieces that I could slap back on there. Based on the few pictures I could find, it appears that you don't recycle any of the lower spring mount pieces--just jam that purple adapter in the bottom hole. Is that right?
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,302
    Re: Quick KW V3 Installation Question
    Yes and yes. The upper spring perch is retained in position the same way the stock spring was - by a rounded cone that's sticking down, and the upper perch is recessed to go around that cone. The stock spring had a rubber sombrero seated on that cone, but there wasn't anything solid holding that in place.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    ^ correct. It makes adjusting the rears a bit easier id think as well...I just undid the lower control arm bolt and end links off the sway bar...fairly quick, easy and simple.
    Mar 2011
    2,045
    Thanks, both of you! I should have a whole bunch of driving impressions and pictures soon!
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    It's why I could change a rear spring in seconds once the wheels were off...
    liqidvenom is offline Cadillac Owners Connoisseur
    Automobile(s): cts-v
    Feb 2009
    Long Beach Ca
    35
    2,741
    I am going to install my LG coilovers when i have a chance, if i recall there is a bearing of sorts in the front shock tower area. Do we normally have to replace that or do we reuse it again? If so what is that part #
  9. Remove Advertisements
