Ls7 cam swap?? Should I??
Results 1 to 8 of 8
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ls7 cam swap?? Should I?? in Cadillac CTS-V Series Forum - 2004 - 2007; So I've owned my 05 V for about six months now and I absolutely love it. I've already done some ...
    H-town_V's Avatar
    H-town_V is offline Cadillac Owners Fanatic
    Automobile(s): 05 cts-v
    Feb 2013
    341
    So I've owned my 05 V for about six months now and I absolutely love it. I've already done some basic mods(ls7 clutch, magnaflow cat-back, k&n and trans insert). I plan todo revshift MM and bushings this summer
    Unfortunately I cannot install headers or make my car too loud cuz I basically live in a old folks condo unit and they will simply make my life hell if I annoy them with another loud ass exhaust(I previously had LT's on my 06 Titan).
    OK onto the cam... I have a stock ls7 cam laying around and I'm wondering what kinda HP gains it would give me with just my current bolt ons? Basically how would this setup workout and will it still be sorta quite without headers?
    My only goal is to get a little more sound and a couple more HP.
    Thanks an advance for any help.
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Re: Ls7 cam swap?? Should I??
    You would need springs and new rockers, not to mention you would have to check for piston to valve clearance...Get the GT11 cam from LPE. i know it fits in the LS6 with 1.7 rockers. But you still need to swap out the valve springs...
    FYI if you install headers on stock exhaust its not loud...Just dont mess with the resonator and mufflers...
    PISNUOFF Guest
    You wouldn't need new rockers. But the cam sensor is not at the rear of the shaft. You would need an ls2 cam sprocket, timing cover, cam sensor and an extension harness. The ls7 cam is designed for rectangular port heads that flow a ton more than your 243's and have much larger valves. I doubt you'd see any gains, if anything they'd be minimal. Here are the cam specs with 1.7 rockers
    211/230, .560/.557 120+4LSA
    H-town_V's Avatar
    Feb 2013
    341
    Thanks for the help guys. I highly doubted a free cam would actually workout.
    I guess I'll just use it as a wall hanger.
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    Don't know why everyone condemned this, you'll make a pretty noticeable gain with the LS7. It's almost the exact same as the LS9 only the Z06 uses 1.8 rockers vice 1.7. You will need an LS2 front cover and a new cam gear, then extend the cam sensor harness to the front cover swapping both outer wires.
    Cathedral port heads make more power with exhaust biased cams just as with the rectangular port heads, so no worries there. The LS7 cam is installed 3* advanced so you won't really notice the LSA difference (120 vs 117 for the LS6).
    Haters gonna hate.
    PISNUOFF Guest
    Put 1.8's on your stock cam and you won't be giving up much rwHp to the LS7 cam. I'm not hating, I'm just saying it's not worth the $300 savings by not purchasing a better cam. The entire point of his question was that he got it for free and wanted more power on the cheap. Buying 1.8's and springs puts the mod way past cheap so you might as well add the $300 for a cam.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    You cloud cheat and buy a LS9 cam. It still makes decent power in a NA, and its 98% just like the LS7 cam but at half the cost new...
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    You can have headers on stock catback and have gain but no noise...I had that on my caddy with SW headers and stock catback. You head a little bit of noise from the engine side, like its a sewing machine, but thats what everyone says...
    You just have to bring your fabricator the good import beer rather than the cheap stuff...
  11. Remove Advertisements
