Strange LS9 Clutch issue
Results 1 to 14 of 14
2004-2007 Cadillac CTS-V Performance Mods Discussion, Strange LS9 Clutch issue in Cadillac CTS-V Series Forum - 2004 - 2007; I just had the clutch replaced after only about 40k miles. The clutch was not disengaging. Pedal feel was normal. ...
    ronr's Avatar
    ronr is offline Cadillac Owners Enthusiast
    Automobile(s): CTS-V
    May 2004
    Fenton, Michigan
    870
    I just had the clutch replaced after only about 40k miles. The clutch was not disengaging. Pedal feel was normal. I bled it just to make sure and still no disengagement.
    I was buried at work and didn't have time to do it myself so had it towed to the dealership. They replaced it and I took the old parts over to Katech for Jason and I to look them over. The rebuildable piece from the Katech flywheel looked normal. The friction disk was only .015" thinner than new (probably has another 100k miles in it the way I've been driving.) However, we found a surprise.
    Some sort of insulating material had gotten in to the clutch and packed in to the clearance around the captured disk. It looks like some sort of brown almost hair like fiberglass material.
    Any idea where this could have come from and/or how it got in there? I thought the only way into the bell housing was a vent hole and there is way too much of this stuff to have just come in through a small hole.
    Since the parts have little wear should I be able to clean this thing out and sell it?
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Strange LS9 Clutch issue
    It must've come from the heatshield surrounding the transmission. That's the only insulating material in the vicinity.
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,824
    Why would that have been drawn in there?
    I'm coming up to 10k miles on my Katech LS9 clutch, and it's not exhibiting anything out of the ordinary.
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    Mystery solved. I spent some time today picking apart the old clutch and what I thought was insulation was actually the fiber glass binder from the captured disk which seems to have come apart. With the other disk only showing .015" wear it sounds like a defective clutch to me
    PISNUOFF Guest
    It sounds like it can't handle the 4000# car to me.
    Mar 2011
    2,045
    Quote Originally Posted by PISNUOFF View Post
    We need a PISNUOFF Certified™ parts list.
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    I sent some pic's to the guys at Katech and their hypothesis was:
    "That's caused by over-revving the drivetrain. For example, if you go for a 2-3 shift and accidently put it in first, but don't let the clutch out the input shaft and clutch disks are going drivetrain speed. At 10,000 RPM those disks can come apart. The burst speed is much lower when cold also."
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by FuzzyLogic View Post
    Said list would be very short
    Quote Originally Posted by ronr View Post
    **** that. That is a real ******* explanation.
    PISNUOFF Guest
    My discs looked perfect when the straps broke on both of my LS9's.
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    Here's a pic showing some of the carnage. Straps were fine.
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    Does anyone reman these to replace the captive disk?
    killernoodle is offline Cadillac Owners Fanatic
    Automobile(s): 2005 CTS-V --- the RED one :)
    May 2010
    31
    281
    It seems like you would be able to drill out the rivets and replace them with bolts on the captive disk. I wouldn't be afraid of doing that.
    Use grade 12.9 bolts and loctite.
    Harder part is going to be finding replacement friction disks.
    Den_93's Avatar
    Den_93 is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS V
    May 2008
    Milford, MI
    316
    You can buy a new presure plate and disk online for about $450 GM PN# 24260226 AC# 24260226. Theres a dealer in New Hudson if you want to save on shipping.
  16. #14
    ronr's Avatar
    May 2004
    Fenton, Michigan
    870
    Thanks, I may give that a try.
  17. Remove Advertisements
