Revshift - Page 3
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 45 of 45
Like Tree19Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Revshift in Cadillac CTS-V Series Forum - 2004 - 2007; Fuzzy must have been picked on as a child but i can tell he never gave in.. the guy that ...
  1. #31
    vOwnR is offline Cadillac Owners Member
    Automobile(s): 05 CTS V
    Jan 2013
    13
    Re: Revshift
    Fuzzy must have been picked on as a child but i can tell he never gave in.. the guy that can read the instructions but cant torque a bolt.
  2. #32
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by vOwnR View Post
    You in OK?
  3. #33
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Re: Revshift
    Honestly dude, just let it go. Fuzzy has said the same or worse to most other people on here. On the other hand, he is intelligent and dedicated to perfecting this car. We all benefit. Sit back, learn, and ignore the noise.
  5. #34
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: Revshift
    Quote Originally Posted by FuzzyLogic View Post
    The Revshift coupler installation instructions (posted all over their website) indicate that driveshaft misalignment should not exceed 0.020". If you did not have the intention of or ability to precisely shim your transmission to achieve that tolerance, you should have never purchased the coupler.
    Straight up: follow Revshift's instructions. You're not going to find a magical alternative that permits you to run a solid coupler with a massively misaligned drivetrain. I can't comprehend why you failed to follow the instructions--Revshift is not trying to make things artificially difficult for you to install their product. It's in their best interest for your installation to succeed.
    I know this thread got derailed but...Fuzzy is right. That is a tight alignment. I have performed countless shaft alignments using double dial and laser and 0.020" is more than just eyeball'n it. Depending on how misaligned your drivetrain is...could be 1-2 hrs getting it just right. I've always used stainless steel shims and never sandwich more than 3 because they will compress and throw off your readings - just up the size. I just saw an older post where good advice was given on possible misalignment due to MM & transmission mounts. The Revshift mounts will stiffen those areas whether on a lift or on the ground - basically solid and eliminates deviation in driving conditions. Then you can start shimming to align your solid coupler.
    This is not a simple DIY when you have to precisely align a shaft - constant remeasuring and a lot of patience to get it done correctly. It involves offset as well as angularity measurements - helps to know simple geometry.
  6. #35
    Jan 2013
    13
    Re: Revshift
    Quote Originally Posted by thebigjimsho View Post
    You in OK?
    Yea I am in OK
    Quote Originally Posted by philistine View Post
    Never said Fuzzy was wrong he is just a smart ass. Are you shimming the trans and/or the carrier bearing?
  7. #36
    philistine's Avatar
    Sep 2011
    821
    Re: Revshift
    I don't know the alignment/misalignment conditions you have. If you are destroying the coupler...there is misalignment. Start with stiffening your mounts then move to the transmission shimming after careful measurements. If you have a decent "rough" alignment, a test drive will not destroy the coupling but might suffer vibrations. You have to work through the vibrations and start shimming (washers work too) in other places. Do not shim in different places at the same time...carrier bearing and transmission. One alignment on one end - test. Rinse and repeat.
    I could bore you with vibration theory and resonance but your ears are your feedback. A solid coupler like Revshift is made for a very stiff drivetrain...no Cadillac float on air shit.
    I feel like I'm stating the obvious here or did I miss something? Let me recall what I think I understand...you purchased a solid drive shaft coupler that is designed for precise alignment. This coupler was then installed in a system that was not designed for precise alignment. The expectation was that the rigid coupler would perform better than the flexible coupler with no other changes to the drivetrain. The result was failure of the solid drive shaft coupler. If this is the case, then you introduced a component that was not correctly implemented into your particular system (setup, whatever). Hmm, well be prepared to chase torsional vibrations after you solve the shearing of the solid coupling.
  8. #37
    Automobile(s): ZIP
    51,885
    Yea I am in OK
    John was asking me in your behalf. But I explained you were probably the guy here asking and that I couldn't help...
  9. #38
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    577
    Love RevShift despite the small delays, I run a small business on the side myself and can attest to how much work is involved and how much shit your have to eat from customers who want instant gratification, people that bitch and moan about waiting 2 while weeks for a part that has to be fabricated need to find another hobby in my opinion, especially a part they broke themselves from improper installation.
    But that's just me and my opinion doesn't mean anything really, but wanted to at least show my support for Revshift before they decide its not worth all the effort and complaining and quit making these parts, then we're all ****ed and stuck with OEM...
    By the way Revshift release your shock bushings now! Haha
  10. #39
    Jan 2013
    13
    Re: Revshift
    Quote Originally Posted by etcts-v View Post
    24 Hour Wrecker and a shop. I have an idea.
    Just looking for a reply. Got one here faster than phone or email.
    robojesus and robojesus like this.
  11. #40
    robojesus is offline Banned
    Automobile(s): of
    Aug 2012
    gay
    184
    Re: Revshift
    I think everyone just needs to quit being a douchebag.
  12. #41
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Revshift
    Quote Originally Posted by robojesus View Post
    It's the internet....that's what happens.
  13. #42
    sgtdestruction is offline Cadillac Owners Fanatic
    Automobile(s): 2007 Silver
    Mar 2012
    Nashville, TN
    38
    132
    Re: Revshift
    Quote Originally Posted by Revshift View Post
    Big changes are happening within Revshift. This will all become apparent very soon. Unless, our happy customers don't speak up.
    Ordered Motor Mounts (80A) from RevShift a few months ago and received them 8 days later. Excellent turnaround time. Installed in less than 3 hours and extemely happy customer.
  14. #43
    philistine's Avatar
    Sep 2011
    821
    Re: Revshift
    Quote Originally Posted by sgtdestruction View Post
    Yeah this was kinda like my experience too. This isn't a product that is going to prevent the drivability of your car while waiting. If it's made to order then expect a longer turn around time. I've modded many cars with varying degrees and you have to accept some stuff is...CUSTOM! Honestly, the only thing I would complain about with my experience with them is...where is my sticker???! I put those on my toolbox!
  15. #44
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Re: Revshift
    As of this week, we are all caught up with backorders and parts are being made for stock. Shipping will be a lot faster than the previous months. We are getting to our 24 hour shipping goal quickly.
    PM me your name and I'll mail you a surprise.
    lollygagger8 and lollygagger8 like this.
  16. #45
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    Hey RevShift, just got my shipping info from you guys. Just wanted to say that in the future just tell people when stuff is going to take a while. Most people are willing to wait patiently if they are told up front.
    Can't wait to get my diff bushing and get it in, this clunk is driving me nuts.
  17. Remove Advertisements
