sqeaking from front suspension possibly lower control arm bushing?
Results 1 to 2 of 2
2004-2007 Cadillac CTS-V Performance Mods Discussion, sqeaking from front suspension possibly lower control arm bushing? in Cadillac CTS-V Series Forum - 2004 - 2007; I am noticing loud creaking and squeaking from front suspension at low speeds and while turning. I took my kw ...
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    I am noticing loud creaking and squeaking from front suspension at low speeds and while turning. I took my kw shock coil over's apart this weekend and couldn't pinpoint any movement so I buttoned it back up and still creaks at low speeds. I was looking through old tsb's and found this, has anybody done this disk install on their own or had the dealership perform it? Its a disc put between the washer and bushing to prevent metal on metal contact.
    tsb 06-03-08-008B
    part# 19150047
    color pictures of install
    http://www.brakeandfrontend.com/issu...ontentid=78487
    I have read rumors that revshift or creative steel is/was looking at producing front control arm bushings. Anybody know if that was lower bushings and how close they might be on it?
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: sqeaking from front suspension possibly lower control arm bushing?
    I haven't had this problem. If you can't locate the source with a visual like the TSB you referenced, try lubing it up. I use Prothane Super Grease.
    You also might want to check your PS fluid since you mentioned it happens during turning.
