ls7 Clutch swap trouble bleeding clutch!!
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 43
2004-2007 Cadillac CTS-V Performance Mods Discussion, ls7 Clutch swap trouble bleeding clutch!! in Cadillac CTS-V Series Forum - 2004 - 2007; So I swapped in a ls7 flywheel, clutch, pressure plate, slave cylinder, also a 36" remote bleeder from monster. I ...
    D-RoKK is offline Cadillac Owners Fanatic
    Nov 2012
    320
    So I swapped in a ls7 flywheel, clutch, pressure plate, slave cylinder, also a 36" remote bleeder from monster. I also have a mityvac. I cant get ANY feel in the pedal and everything is connected and torqued down to spec. Maybe I'm just doing this wrong, but can anyone give me advice of how to do this or a procedure to bleed it?
    Thanks!!
    pato is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    Aug 2011
    186
    Re: ls7 Clutch swap trouble bleeding clutch!!
    I think you still have a lot of air in the system, keep bleeding until it comes up.
    I started bleeding with a simple vacuum pump for about 30 minutes and was not getting any pedal.
    I hooked up the bleeder in the link below and was done in 5 minutes. It requires an air compressor though.
    http://www.amazon.com/Mityvac-MV6835...+brake+bleeder
    Nov 2012
    320
    Damn 150? For that price I could have a caddy dealership bleed it haha. I have a simple hand pump one..
    Ive been told to stay around 10-12 Hg of pressure. Do I just keep doing that until it wont do anything else? I dont want to pull any seals...
    Is my clutch pedal going to feel like it should right off the bat?
    Aug 2011
    186
    Yea, if you have a hand pump one, it's going to take a looooong time.
    I think I was doing 20-25 psi with the hand vacuum pump for over a half hour and it got me nowhere.
    I don't think you can pull any seals with what you're using. Keep bleeding.
    Nov 2012
    320
    So im assuming that no more air bubbles will appear when I am to be done vaccum bleeding? Then do I just bleed traditional style? Or should it all be done with the vaccum?
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    i use pressure instead of vacuum, get the Motion brake bleeding kit, its from 50$
    http://www.motiveproducts.com/
    Works like a charm, and since you have the remote bleedin kit, its less moving around...
    Bacon V's Avatar
    Bacon V is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS-V
    Jul 2012
    33
    107
    Did you make sure to close the check valve on the end of the remote bleeder when you were done bleeding? It should only take a few pumps to bleed it, close the valve, pump twice and feel your new firm pedal
    Nov 2012
    320
    Hold on here, this is how ive done it..
    Have the bleeder valve closed, stick the mityvac in the master, build pressure, relieve pressure and add fluid. Is that right??
    Bacon V's Avatar
    Jul 2012
    33
    107
    Get rid of the mityvac, you won't need it.
    Fill reservoir, pump pedal a few times slowly, top off reservoir, open check valve half a turn or so and put into a cup or container. Push clutch in and hold a couple seconds, release and wait a second, pump and wait, release, fill reservoir, pump and wait, release and wait, pump and wait, release, close check valve, fill reservoir, pump pedal and it should be firm. Repeat the pump, release, fill process until bubbles are gone.
    In my experience, pressure from the pedal works better thana vacuum.
    Nov 2012
    320
    So you release while its open?
    Bacon V's Avatar
    Jul 2012
    33
    107
    If the bleeder has a check valve on it, then yes. It'll close as soon as the pressure drops at the end of the pedal travel
    Nov 2012
    320
    It doesn't have a check valve... just called monster.
    Jeff James is offline Cadillac Owners Member
    Automobile(s): 07 V1
    Oct 2011
    Sonora, Ca.
    57
    97
    Put the end of the bleeder without check valve in another container with some fluid in it and keep the end below fluid level. Bleeding is only about moving fluid not pressure. Just move the pedal(don't pump) a few times and watch for air movement.
    Another way might be to just have the end of your bleeder in the fluid and open it. Let it gravity bleed for a little while. The air will work it's way to the reservoir and out. Works with Brakes!!
    Good luck
  16. #14
    Nov 2012
    320
    Quote Originally Posted by Jeff James View Post
    Good luck
    Im thinking of gravity bleeding while im at work today which is a 3.5 hr shift. How can I make sure the master wont run dry?
  17. #15
    Bacon V's Avatar
    Jul 2012
    33
    107
    Buy a check valve at the auto parts store for 3 dollars and thread it in the end of your line. Tick comes with a check valve on it.
  18. Remove Advertisements
