Oil Cooler from V2 to V1?
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V Performance Mods Discussion, Oil Cooler from V2 to V1? in Cadillac CTS-V Series Forum - 2004 - 2007; Hey, I've been seeing CTS-V2 oil cooler showing up on eBay and wondered if anyone had any idea how you ...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Hey, I've been seeing CTS-V2 oil cooler showing up on eBay and wondered if anyone had any idea how you might fit one on a V1. Example auction:
    http://www.ebay.com/itm/GM-AC-DELCO-...-/290891122796
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Re: Oil Cooler from V2 to V1?
    You will have a clearance issue with your chassis.
    Stick to the usual Setrab oil cooler and improved racing thermostat oil cooler adapter and you will be fine.
    soflarick's Avatar
    soflarick is offline Cadillac Owners Enthusiast
    Automobile(s): none
    Sep 2009
    Florida
    626
    The Improved Racing adapter works with headers? I know it's extremely thin.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    I have it with my1 7/8 kook headers
    AAIIIC's Avatar
    AAIIIC is online now Super Moderator
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,537
    Pics or it didn't happen.
    Seriously, I want to see how the hoses are run and what fittings you used.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    soflarick's Avatar
    Automobile(s): none
    Sep 2009
    Florida
    626
    So would I. I spoke with IR for a while about trying their adapter since it's the thinnest adapter out there.
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    You need two 90* elbows to connect to its adapters and you can route the hoses between the block and engine mount.
    Quite easy
    AAIIIC's Avatar
    Aug 2007
    6,537
    I'm not worried about the block and the engine mount, I'm worried about the very hot header that is right there.
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by AAIIIC
    I thought Naf mounted the headers after the improved racing piece was installed.
    AAIIIC's Avatar
    Aug 2007
    6,537
    The install is fine - I can install the TPIS adapter with the headers installed (I've done so a couple of times as I've tried to figure out how to make it work). The problem is that the fitting and/or hose coming off the angled port is going to have to squeeze between the header primary and the block with a fraction of an inch to spare. Way too close for my taste.
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    We had to drill and tap a Moroso-like adapter for my setup. Keep in mind we used -12 lines but none of the other TPIS-like adapters worked for me with 1 3/4 kooks...Call Mark at Phoenix Performance and he can get one set up for you guys
    Naf's Avatar
    Naf
    Apr 2007
    2,090
    i installed the IR adapter with no headers on. Its the only way to get it all to fit with limited space, the headers dont come close to the block on my setup, with plenty of space for the hoses. I also have the Nomex -10 hoses for anything larger and i am wasting oil pressure. The outlet holes from the block are -8 but i let it open to a -10 for a little more expansion to cool it all off
  15. Remove Advertisements
