Revshift Motor Mounts with Headers - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 41
Like Tree4Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Revshift Motor Mounts with Headers in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by darkman Always bareback. Figures. Pull out!...
  1. #16
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Revshift Motor Mounts with Headers
    Quote Originally Posted by darkman View Post
    Pull out!
  2. #17
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by lollygagger8 View Post
    Pull out!
    Doesn't work... I have a little kid cuz of that lol
  3. #18
    PISNUOFF Guest
    I also have a kid from that.
    Wrap the mounts with something, header wrap works fine.
  5. #19
    Apr 2008
    Indiana
    4,913
    Ok, I give......I have a kid from that too. But my daughter rocks, so I wouldn't have it any other way.
    But that method did work for a really long time! lol
  6. #20
    Bacon V's Avatar
    Bacon V is offline Cadillac Owners Fanatic
    Automobile(s): '04 CTS-V
    Jul 2012
    33
    107
    Ok, wtf... I have all 7 upper bolts loose (fuzzy - i had two stuck like you did. Still can't believe i got them out) and all 4 bottom bolts off/out and now i can't get the sub frame to let go of the bottom mount bracket. I jack the engine and the whole car lifts up. Any ideas? I've hit it with a hammer and tried a pry bar to no avail
  7. #21
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    There are only two bottom bolts on each motor mount. The big one on the bottom (the inverse Torx stud should come out with the nut) and one on the top, facing the front of the car.
  8. #22
    Bacon V's Avatar
    Jul 2012
    33
    107
    I've got both of the bottoms on both sides out. Both nuts came off without the studs, but the studs came out easily. I've got the car on ramps with wheels on - how much will the motor compress the suspension? Am i just not jacking it high enough? I don't want to collapse the oil pan by lifting too much
  9. #23
    Mar 2011
    2,045
    Quote Originally Posted by Bacon V View Post
    A standard round jack plate will not collapse the oil pan if you place it on the rear of the oil pan, right in front of the subframe. It should easily lift off, assuming that you've removed your headers. It doesn't weigh that much.
  10. #24
    Bacon V's Avatar
    Jul 2012
    33
    107
    Headers are off and I'm using a floor jack with a 2x6 on it. The car raises about 1-2 inches before i stop. Guess I'll try lifting a little more in the morning. I even hit the mount with a hammer while i had tension on them. And here i thought accessing the bolts would be the hardest part...that was the easiest part
  11. #25
    Mar 2011
    2,045
    Is it possible that the engine is hitting the tower brace on top? Or do you have a hard intake manifold connection?
  12. #26
    Bacon V's Avatar
    Jul 2012
    33
    107
    Strut tower is out and stock intake. I was getting frustrated with the stuck bolts so i probably didn't give it enough of a chance.
    If it makes you feel better, the two bottom drivers side bolts on the upper bracket were so stuck that my 450 ft-lb impact wrench couldn't take them off. I did manage to break a 1/2" universal joint though. Ended up getting them of with a black oxide impact socket, 24" breaker bar, and an extension. Sounded like a gunshot under the car when it came loose. Thought for sure i broke the bolts, but they came out by hand after that. Must have been seized between the bolt flange and the bracket.
  13. #27
    Mar 2011
    2,045
    Depending on how much time I have this weekend, I may try a nut extractor and a 1/2" drive extension on the end of a 3' breaker bar. I know for certain that I can do 250 ft-lb, and if that isn't enough, I'll weld a socket to that thing and drop a 5' pole on the end of it.
  14. #28
    Jul 2012
    Wildomar, CA
    31
    976
    Quote Originally Posted by FuzzyLogic View Post
    If you weren't on the other side of the country I would let you borrow my 5' long pole.... bahaha. Have you guys tried applying some heat to it, perhaps that might help out. I know having an open flame near motors and such isnt the best idea but might be worth a shot.
  15. #29
    Mar 2011
    2,045
    Are you saying the difference in the thermal coefficient of expansion between the aluminum block and the steel bolt would help loosen it up?
  16. #30
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    That you know of....
  17. Remove Advertisements
