REVSHIFT poly hardness selections for minimizing NVH increase
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V Performance Mods Discussion, REVSHIFT poly hardness selections for minimizing NVH increase in Cadillac CTS-V Series Forum - 2004 - 2007; Good day, all. I am about to place an order from RS for everything they have currently for the V. ...
    hambycm is offline Cadillac Owners Member
    Automobile(s): 2006 CTS-v
    Jan 2010
    9
    Good day, all. I am about to place an order from RS for everything they have currently for the V. Below is the parts list, along with the hardness level that I am leaning towards for each. I would like some feedback on my choices of hardness, given the type of driving that I do mostly. So far, my car has been strictly a daily driver, but I am considering some upcoming auto cross days. I would like to stiffen the car up, but at the same time I don't want to increase NVH horribly. So my goal is to use the hard poly for areas where it won't contribute as much to NVH, and the softer poly where it would make a noticeable increase. In the list below, I have taken my best guess at pairing hard poly with parts that don't affect NVH, and soft poly with those that do. Does my matching make sense for each part? Do any of my "hard" selections contribute noticeably to NVH, or could I get away with upgradeing from soft to hard for any of my "soft" selections?
    Diff mount - hard
    Rear cradle - soft
    Rear trailing arm - soft
    Upper control arm - soft
    Motor mounts - soft
    Trans mount insert - hard
    Flex disc coupler - hard
    I appreciate the opinions!
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    Re: REVSHIFT poly hardness selections for minimizing NVH increase
    diff mount will definitely contribute to NVH as would transmount insert. They don't make the flex couple with the hard durometer poly. I would go with the hard durometer poly for the trialing arm bushings and UCA bushings and nothing else is NVH is a big concern. the "softer" poly is already much stiffer then the OEM rubber.
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    We only make the coupler with the harder 95A polyurethane but we just color the bushings blue because it looks better than red. We can actually make the polyurethane any color we want. The trans mount insert is only available in the softer 80A.
    If you don't want nvh then stick with 80A motor mounts. That is the most important thing here. You most likely are going to see only minor differences in nvh with the rear end bushings.
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    The simple answer is 95A everywhere except the transmission mount (which you don't have a choice on) and the motor mounts.
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    I agree with ^^^^^^^
  8. Remove Advertisements
