Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Installed Revshift Bushings today
    05txctsv is offline Cadillac Owners Member
    Automobile(s): 05 CTS-V
    Dec 2012
    Texas
    20
    Installed the Revshift trans bushing today. Nice to say it makes the shifts more precise and accurate.
    The trans bushing looked like others i have seen and now this is what it looks like.
    Super easy to install, just spray trans mount with WD-40 and get a big flathead screwdriver or prybar.
    wedge prybar on driveshaft bolt and pry it in, no problem.
    Now the rear diff bushing involved more work. Removal of exhaust helped alot. Followed others instructions and
    easy peasy. I even used the OEM kent tool (which is for sale for $45). Here are a couple of picks.
    Now here is the bushing i pulled out. once i got the tool on and started after a few turns this just fell out. doesnt look OEM.
    Any Ideas?
    silentwig's Avatar
    silentwig is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2012
    MD
    32
    111
    Re: Installed Revshift Bushings today
    The trans mount you replaced looks like a creative steel. Both bushings looked fine. I guess if the trans mount from revshift makes cleaner shifts, nice.
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Diff bushing looks like Creative Steel. Do you notice a difference with the RS diff bushing?
  5. #4
    Dec 2012
    Texas
    20
    diff bushing was loose and i could place back in by hand. it was not good. make a horrific bang when letting off gas in first or second and you can see that it was spinning in place. Now no bang and fun.
    little bit better locating revere.
  6. #5
    Motown Cad is offline Cadillac Owners Fanatic
    Automobile(s): 07 Silver V Sport Susp.
    Jun 2011
    Southern MD
    51
    147
    Is this differential bushing what is causing that horrific bang? I had my friend drive car after we were done working on it and it scared the shit out of us. He was shifting fast with clutch and throw and boom. I guess we get used to it knowing how to shift to avoid that. But if this bushing eliminates that .....I'm in.
  7. #6
    Mar 2011
    2,045
    Quote Originally Posted by Motown Cad View Post
    If the bang came from the front...motor mounts. If it came from the rear, differential mount.
  8. #7
    Apr 2012
    Seattle, WA
    731
    Could also be the stock flex disc that winds up and snaps back under high torque. The cure for it is the revshift guibo.
  9. #8
    Dec 2008
    377
    Hamstar I get that... I have not wanted to mess with it though
  10. #9
    Jun 2011
    Southern MD
    51
    147
    Sweet! Definitely from the rear. Thanks I'm in. These guys are in Warren, MI. maybe Rand or somebody could stop by when they're on that side of town.
  11. #10
    kciaccio is offline Cadillac Owners Fanatic
    Automobile(s): 2007 CTS-V
    Apr 2012
    47
    154
    Quote Originally Posted by 05txctsv View Post
    Any Ideas?
    Is this the tool?
    http://www.ebay.com/itm/Kent-Moore-S...-/360475432051
  12. #11
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Dec 2008
    Huntsville
    49
    291
    Quote Originally Posted by HAMSTAR View Post
    So the stock flex disc contributes to the parade clunk? I'm about to do the clutch and pressure plate and want the recently developed clunk gone.
    BTW I already have the CS diff bushing and block, RS trans mount, RS cradle mounts and TA mounts going in this weekend, RS motor mounts going in with headers - soon.
  13. #12
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by sssnake View Post
    Not, not parade clunk. If you haven't experience that rubber-band snap-bang, I would leave the flex disc coupler alone. For me, it only occurs if accelerating hard out of a left turn in low gear when the back wheels slide a little then regain traction.
  14. #13
    sssnake's Avatar
    Dec 2008
    Huntsville
    49
    291
    Hmmm. Occasionally I get a series of surges when in low gear and coming out of a turn. I had assumed this was due to the motor mounts. I don't get any banging noise with this.
  15. #14
    Dec 2012
    Texas
    20
    Quote Originally Posted by kciaccio View Post
    this is the tool that was in the box i purchased......dont know what that tool is
    when you gas it hard the suddenly let off gas, the loud clunk in back is what this fixed. Nice upgrade.
  16. #15
    rguzman1 is offline Cadillac Owners Member
    Automobile(s): cts
    May 2013
    27
    i having the same issues a clunk when i release the gas . or going up hill . rpm also drops . what should replace??
  • You may not post replies
