New to Community, any advice helps. - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
2004-2007 Cadillac CTS-V Performance Mods Discussion, New to Community, any advice helps. in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by DMM I would advise against Royal Purple. I had a brand new GEN IV rear installed under ...
  1. #16
    Código_Velocé's Avatar
    Código_Velocé is offline Cadillac Owners Member
    Automobile(s): CTS V (Gen-1)
    May 2012
    Oxnard, CA
    10
    Quote Originally Posted by DMM
    I would advise against Royal Purple. I had a brand new GEN IV rear installed under warranty and I changed the fluid after break in using Royal Purple and had nothing but problems. It would chatter at low speeds when going straight and was much worse making turns or during parking lot maneuvers. Changed it again with Redline (within 2k miles) and never had another problem at all.
    The Redline product was noticeably better than the Royal Purple...you could feel the difference in lubricity just rubbing your fingers together with it.
    The rust on the hubs and splines has plagued GM for some time now. As I stated, GM advised to use a small file to chase each spline before reassembly...this was on the older C4 Corvettes though. GM also had a problem with the splines of the slip yoke sticking to the transfer case output shaft that would result in a "thud" during initial acceleration on the '99 Yukon's and Tahoe's. The "official" fix from GM (per TSB) was to change the transfer case fluid with auto-trak II; however, if you didn't pull the drive shaft and chase the splines you'd have a come-back waiting for you in less than thirty days.
    Off topic I know, but this has been a running problem for GM.
    Good to know. I will definitely drain the Royal Purple out and look for Red Line. When adding the Red Line to the Diff, does it require an additive? I appreciate all the info you guys have given me, really appreciate it. :Now to look for some Red Line:
  2. #17
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Re: New to Community, any advice helps.
    Quote Originally Posted by Código_Velocé View Post
    The Red Line already contains the friction modifier: http://www.redlineoil.com/product.aspx?pid=133&pcid=4
  3. #18
    NCOGNITO's Avatar
    NCOGNITO is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V - Black Raven
    Apr 2012
    39
    283
    Here's the thread I started on a similar issue, but I noticed that you're calling it a clicking noise, when mine was a distinct pop:
    http://www.cadillacforums.com/forums...shop-says.html
    The link to the most descriptive video is broken, I reuploaded the video again here -->
    You can hear 3 distinct pops at 0:19, 0:21 and 0:23.
  5. #19
    jmargo is offline Cadillac Owners Fanatic
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    If the axle nut is properly torqued how is it moving and popping ?
  6. #20
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,815
    Quote Originally Posted by NCOGNITO View Post
    ... You can hear 3 distinct pops at 0:19, 0:21 and 0:23.
    Is this the rusted spline issue and now it's fixed or is this still lingering? Not knowing anything else, I'd be looking at the CVs, too.
  7. Remove Advertisements
