Page 1 of 2 12 LastLast
Results 1 to 15 of 30
Thread: Questions about clutch replacement for 04 CTS-V
    Jalyousef is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2010
    Dallas, TX
    9
    I have an 04 CTS-V that I bought at 40k miles. I do not know if the original owner replaced any clutch parts or not before I had purchased it. I now have 75k miles on it, and have not really noticed anything wrong with the clutch, however it is a little more difficult as far as shifting goes, especially reverse.
    I'm wondering what are some signs of my clutch needing to be replaced? I've been thinking about buying the whole LS7 clutch kit, but don't want to do it if it's not needed.
    Thanks!
    PISNUOFF Guest
    Re: Questions about clutch replacement for 04 CTS-V
    Have you bled the clutch fluid?
    rand49er's Avatar
    rand49er is online now All V1s should be maggied.
    Jan 2005
    South Lyon, MI
    68
    13,831
    I doubt you need a clutch. But, there are two things you could do that may help you. First of all, check your hydraulic clutch fluid level. These cars are notorious for losing clutch fluid making shifting less than it can be. You could go one step further and have it replaced and bled. If you're still having problems, there are bushings that can be replaced in the linkage. There's a thread floating around by Cadzilla that is the most inclusive shifter bushing thread I've ever seen. Truly amazing.
    To check your clutch, drive about 50-ish MPH in sixth gear. Push the clutch pedal in, rev the motor slightly, then let the clutch back out somewhat abruptly. If it grabs with a jerk, then it's good. If it only slowly engages, your clutch is on its way out.
  5. #4
    boomer06's Avatar
    boomer06 is offline Cadillac Owners Member
    Automobile(s): CTS-V
    Feb 2013
    6
    if you end up needing a new clutch i have the stock clutch out of an 07 V that the guy gave me whenever i bought mine. shoot me a text if your interested. 512-815 nine four 35
  6. #5
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    If you do a new clutch, take a look at monster as I replaced mine with a LS7 set-up and hate where the pedal grabs,just off the floor sucks ass.
  7. #6
    Scott2012's Avatar
    Scott2012 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD CTS
    Jul 2012
    Minnesota
    40
    261
    Quote Originally Posted by Mn800r View Post
    Which Monster would you go with?
    Did you do the LS7 kit from Lindsey Cadillac?
    I have gear chatter and plan on getting a new flywheel, clutch, slave in the next few months
  8. #7
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,208
    Quote Originally Posted by Scott2012 View Post
    The forum members here that have installed Monster Stage 3 clutches have had problems. On the other hand those with lower stage Monster clutches have not reported the same problems. For expample:http://www.cadillacforums.com/forums...-2-5-15lb.html
  9. #8
    Manseeno is offline Cadillac Owners Member
    Automobile(s): '04 CTS-V (No Moonroof)
    Apr 2012
    Bay Area, CA
    38
    55
    I have a Monster Level 1 that will be getting installed into my '04 soon (hopefully this week); I'll report back once it's in.
  10. #9
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    Your pedal never came up higher? I have an LS7 in mine and the pedal is perfect, I did bleed the heck out of it when I installed it.
  11. #10
    NC-V is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Feb 2010
    Mooresville, NC
    113
    Monster Stage 2 here, very happy with engagement position with LS7 slave and/or Monster slave (engage at same point, not at bottom, not at top). Not grabby, easy to start from stop. And much better performance than the stock clutch/flywheel.
  12. #11
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    My oem clutch was still going strong at 120k miles. the Dual Mass flywheel on the other hand was clunking like crazy.
    I replaced mine with the katech Twin Disk. It is expensive BUT you get OEM quality, and the performance of a twin disk. One of the best mods I've done to my car. It revs like crazy now. Was blown away by the difference. I should have done this mod a LONG time ago.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  13. #12
    WesH8398's Avatar
    WesH8398 is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2010
    Sarnia, Ontario, Canada
    35
    897
    Quote Originally Posted by etcts-v View Post
    Did you go with an OEM LS7 flywheel, or lightweight? What'd ya think of the upgrade? Can you feel a difference?
  14. #13
    Mar 2011
    2,045
    If you over-torqued your pressure plate bolts, the fingers on the pressure plate will retract inwards and you'll always be stuck with an "on-the-floor" disengagement point. If I had to guess, you followed the LS7 Z06 user's manual, which specifies 15 lb-ft, 37 lb-ft, and 74 lb-ft star bolt sequencing (if you used torque specs at all).
    Through testing, I found that the LS7 pressure plate fingers begin to move inward right after you cross the 50 lb-ft threshold. At 74 ft-lbs, those fingers have retracted so far inwards that you'll be lucky to get the clutch disengaged at all. After having the transmission in and out of the car 7 times in the summer of 2010, I discovered that the stock CTS-V 52 ft-lb torque specification was just about perfect for the LS7 clutch swap.
    I recommend using blue locktite and torquing your pressure plate bolts to 50 ft-lb. I've been running that way for 12,000 miles with zero problems. Since I'm about to replace this clutch with a McLeod RXT, I can also provide exit data on the outgoing LS7 clutch, if requested.
  15. #14
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    68
    13,831
    Quote Originally Posted by FuzzyLogic View Post
    ... After having the transmission in and out of the car 7 times in the summer of 2010 ...
    Fuzzy, you and a couple of other guys on here (PISNUOFF is one) amaze me with your tenacity on this stuff. My patience would've worn thin after the second time.
  16. #15
    Mar 2011
    2,045
    Quote Originally Posted by rand49er View Post
    This is my only car. So, for me, it's not a question of "do I want to get it exactly right"--I have to.
  • You may not post replies
