need cam help
Results 1 to 11 of 11
Like Tree2Likes
  • 4 Post By 2007ThunderV
2004-2007 Cadillac CTS-V Performance Mods Discussion, need cam help in Cadillac CTS-V Series Forum - 2004 - 2007; Saw this on craigslist...I dont know anything about cam specs but I want to cam my V. Will this work ...
    platinum_V is offline Cadillac Owners Member
    Automobile(s): 2005 platinum Cts-V
    Dec 2012
    30
    67
    need cam help
    Saw this on craigslist...I dont know anything about cam specs but I want to cam my V. Will this work without any mods and with those specs, will it be loud and a hard idle? I daily drive her and I dont want anything TOO radical.
    http://miami.craigslist.org/mdc/pts/3574037437.html
    Any help with be much appreciated.
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Re: need cam help
    Sorry, that cam is a terrible choice for a daily driver. It has extremely high intake and exhaust durations. It will buck and surge like crazy at low RPMs, and rob power at low RPMs, and need to be revved extremely high. Like the ad says, this is a race cam.
    Dec 2012
    30
    67
    Re: need cam help
    Im glad I asked! So what would be a good cam for daily driver but also sounds like I have a cam, I dont want anything to quiet.
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: need cam help
    Additionally there is so much more to a cam install than just the actual cam. As with all mods - Cheap, Powerful, Reliable: pick 2.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,161
    Apr 2012
    Seattle, WA
    731
    Re: need cam help
    trukk is right, there is a lot more to it that just the cam. Your best bet is to talk to a tuner/builder about your current setup and future plans and have them spec a cam for you.
    For the LS6, I personally like the 228/234 111+3 LSA. If you want to buy off the shelf, lately Tick Performance has been putting out some cams that are very similar to what my local tuner puts out. You might want to check out their site and call them up for advice. Also, the streetsweeper HT by flowtech induction plays very well in our engines. Give those guys a call, tell them your setup and your needs and ask them what they recommend.
    NC-V is offline Cadillac Owners Fanatic
    Feb 2010
    Mooresville, NC
    113
    Re: need cam help
    That cam is waaayyy too radical for a street LS6. If they got the part number right, then the specs are wrong that they listed. The Comp 54-466 11 is rated at 259/267 @.050" lift, .624/.624" lift on a 115 LSA. You would run into many issues as already stated. You would need to upgrade the entire valve train on the LS6 and I'm pretty sure that cam would poke a valve through a piston. That would be a decent cam in a larger displacement motor (LSX 454).
    The cam Hamstar mentioned would be a good choice if staying N/A.
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,161
    Re: need cam help
    Quote Originally Posted by NC-V View Post
    I came at it from the other direction - I assumed the part number was wrong and cross referenced the specs. The 281/283 duration specs are "advertised durations" and not the @.50 lift specs we all use for comparison. Based on my cross reference I believe the cam in question is Comp's XER281HR which has durations of 232/234 @.50 lift and an LSA of 112.
    If this the cam in question of course, it would still require supporting valvetrain modifications and is not suitable for use with the stock exhaust manifolds.
    Apr 2012
    Seattle, WA
    731
    Re: need cam help
    As usual, darkman has the answer. Not as bad choice as we thought before, but still rather big for the LS6. Having said that, there are guys out there runnin bigger cams.
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    Re: need cam help
    http://www.youtube.com/watch?v=DbjyD1PdkKw
    i love my 233/239 cam from tsp
    car runs great , no surging, makes good power
    heres a recent video, might be a bit radical for what u want
    Overd0s3 is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V blk/blk
    Dec 2009
    28
    323
    Re: need cam help
    That's a race cam, most def not a daily driver cam. Have fun in a drive through!
    Personally I have a 231/235 and I get good mid range with no surge. Also depends on your tune!
    http://www.youtube.com/watch?v=1XurfVKVV74
    this is mine
  14. Remove Advertisements
