Obx header to stock exhaust
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V Performance Mods Discussion, Obx header to stock exhaust in Cadillac CTS-V Series Forum - 2004 - 2007; Tried to search, but can obx headers be connected to the factory exhaust without cutting if the cat or resonator ...
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    Tried to search, but can obx headers be connected to the factory exhaust without cutting if the cat or resonator pipes aren't used?
    Thanks
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Obx header to stock exhaust
    Quote Originally Posted by 2007V View Post
    Thanks
    Yes. But you won't like the smell and you won't pass emissions.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,306
    Without cutting? No. None of the long tube headers (Kooks, Pacesetter, OBX, SW, etc) have the collectors in a place that a stock exhaust could mate up to without cutting and modifying.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Apr 2011
    85
    Excellent! so I assume kooks are the same way? Ie the mid pipes aren't required.
    I might get the catted obx and try it without them first. Also does it really smell that bad? I didn't notice a smell on my last cattless car.
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    Kooks makes connection pipes that bolt to stock exhaust
    Of course you would need to buy kooks long tubes not obx
    Apr 2011
    85
    Quote Originally Posted by AAIIIC View Post
    Didn't see this. So the only non-cutting of the stock exhaust is with PS and their short connection tubes?
    Also Is eBay or amazon the best price for obx? I saw on another post that they were available new for $490 but I haven't been able to find that source.
    Quote Originally Posted by 2007ThunderV View Post
    I thought that you had to cut a little off the stock exhaust for kooks or obx to use their connection pipes. It's not a big deal just trying to get it planned out.
    Jul 2011
    482
    I have kooks with corsa and there was no cutting everything bolts together
    Iam not sure but check kooks website if their connection pipes for stock cat back require cutting .
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Pacesetter's will require cutting the flange off the cat back , IIRC. The connection pipes or whatever they are calling them, is really just a reducer to fit the factory 2 1/2 inch pipe. The smell will be very noticeable. It will seem as if the car is running extremely rich.
    Apr 2011
    85
    Quote Originally Posted by JFensty View Post
    I'm confused by this. The picture PS shows of the extension has a flange so it looks like it would bolt up to the stock cat back. Are their pictures wrong? I also thought that I read that they are a little long which would imply that nothing is cut, otherwise you would just cut more off.
    Headers: http://marylandspeed.com/pacesetter-...9.html?image=0
    Connections: http://marylandspeed.com/pacesetter-...9.html?image=1
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    I guess they could fit. When I installed mine I did not purchase the extensions. I knew I was going to install cats so it would have been a waste of money. I did have to cut the flange off to install a reducer so I could drive the car to have the exhaust done. Seems like the exhaust would be pushed back an inch or two for the extensions to fit but I could be wrong. Its been well over a year since I did the install.
    Apr 2011
    85
    I think that is right about it being pushed back with the extensions. Maybe I can trim some of the header.
    How do you like the headers?
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    Cutting the exhaust should not be a big deal. You could always weld them back together later if needed (IE save the cut off portion) there should be enough identifying marks on the pipe to align them, or put a good scratch or two across the cut line to align later if you need to.
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Not necessarily true.
    The following is true if you are NOT using cat converters:
    I have Pacesetter LTs without cats, using the extension connectors mated directly into the stock exhaust, without cutting anything.
    The part specifically was
    -PaceSetter 82-1170 Off Road Header Extension for Cadillac CTS-V 04-07
    It goes on amazon for like $70 shipped
    Its a 2 part per header setup, with 1 part that bolts to the catback exhaust (without cat converter, obv), and then it has another part that connects the connector from catback to the header with two bolts that tighten it up.
    In the pic above, you can see the connectors with the flange, and you can also see the part which goes between that connector and onto the header. This clamps down with those 2 bolts, and will hold it all down in place perfect.
    Although this picture is dark, you can see that I still have the front flanges from the stock exhaust.
    As far as being 'pushed back'... MAYBE half an inch. To me, I noticed NO movement in the exhaust to be honest. Just make sure you sit the extensions on correctly. I didn't have a shop do any of the install, I personally did the install. Buy the headers with the extensions, and you can mess around with it to get it to fit perfectly all the way in.
    Only issues I ran when putting on headers with stock catback was 1 pacesetter header wouldn't thread the front o2 in, so I used a thread chaser to get that to work, and I had 1 head bolt break, so I had someone (more skilled than I with a welder, as I don't weld, period) weld a head to the bolt to remove it.
    Again, the above is only if you don't plan on using ANY cat converters. Otherwise, you will have to weld.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  16. #14
    AAIIIC's Avatar
    Aug 2007
    6,306
    Well then, I stand corrected.
  17. #15
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    I really like them. Mine are not wrapped and cool to the touch within 10 minutes of heavy driving. 2 PA winters and no corrosion from salt. Still nice and shiny.
  18. Remove Advertisements
