Revshift rear UCA bushings
Results 1 to 5 of 5
2004-2007 Cadillac CTS-V Performance Mods Discussion, Revshift rear UCA bushings in Cadillac CTS-V Series Forum - 2004 - 2007; Has anyone started or already installed these? did you pull the UCA out and then remove the bushings? did you ...
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    Has anyone started or already installed these? did you pull the UCA out and then remove the bushings? did you have to drop the cradle all the way down? the back bolts are not looking easy to access.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,223
    Re: Revshift rear UCA bushings
    A couple years ago I picked up a set of the GMPP rear upper arms, which have stiffer rubber bushings. I'm a pretty competent mechanic, but I couldn't figure out how the hell to get all the bolts out, so I had Lindsay do it.
    Not that that piece of information helps you, just confirming that it is a big PITA to remove those arms.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    Attached is the service manual procedure.
    Mar 2010
    San Jose, CA
    29
    979
    Thanks darkman. AAIIC yes this is looking to be a bitch but dropping the cradle may give me enough access to the rear bolt to undo it.
    Sweetwilliebrownjr is offline Cadillac Owners Member
    Automobile(s): 06 cts-V
    Jun 2012
    Brandon, ms
    36
    60
    I didn't have to remove the rotors or the shocks. I can see no need to remove the rotor at all. Removing the shock will definitely allow more clearance, but isn't necessary.
  8. Remove Advertisements
