What coil overs do I have?
Results 1 to 6 of 6
2004-2007 Cadillac CTS-V Performance Mods Discussion, What coil overs do I have? in Cadillac CTS-V Series Forum - 2004 - 2007; My front driver shock was leaking oil so I cross referenced the shock numbers and ordered a new shock. Well, ...
    tshort is offline Cadillac Owners Member
    Aug 2010
    25
    My front driver shock was leaking oil so I cross referenced the shock numbers and ordered a new shock. Well, after pulling the shock (actually it's a coil-over) it appears I've probably something custom. I'll try and post a picture of it below but if it doesn't come out, it is a Sachs shock 6MH 25772234 with Ebach springs and a coil over threaded perch attached. There doesn't appear to be any way to remove the threaded perch from the shock to use with the new one.
    Anybody know what I have and how to get a replacement?
    Thanks!
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,201
    Re: What coil overs do I have?
    The threaded perch looks like a Ground Control setup. The shock number does not match what I show for an FE4, but does match a listing for a CTS shock.
    http://www.cadillacfaq.com/faq/index.html
    Aug 2010
    25
    The top 'cap' on the shock, above the threaded perch, will that pop off or is that pressed on holding the internals in?
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,201
    Quote Originally Posted by tshort View Post
    If you go to the link in previous post and click on Suspension/Steering - there is a list of artcles including on installing the Ground Control system with pictures. There are also articles with shock-related part numbers.
    Aug 2010
    25
    I'll do that. Thanks a bunch!
    Aug 2010
    25
    Cool...the top 'hat' just pops off and I was able to adapt the threaded perch to the new shock. Back in business!
  9. Remove Advertisements
