Transmission fluid leaking out of top of breather tube at the track - how do I fix?
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V Performance Mods Discussion, Transmission fluid leaking out of top of breather tube at the track - how do I fix? in Cadillac CTS-V Series Forum - 2004 - 2007; My last track session, I realized that transmission fluid was blowing out the breather tube at the top of the ...
    repenttokyo is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Jan 2009
    1,171
    My last track session, I realized that transmission fluid was blowing out the breather tube at the top of the transmission. Is there any way that I can prevent this from happening in the future? Note - tranny temps never got super hot, and it was a near-freezing day on the track.
    Also, is there a way to add a remote fill to the transmission so I can top it off more easily?
    Thanks!
    Jan 2009
    1,171
    Re: Transmission fluid leaking out of top of breather tube at the track - how do I fi
    Am I the only one who has ever had this problem occur during track driving?
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    I have never experienced this issue. what were your tranny temps reading during the track event?
    Jan 2009
    1,171
    Tranny temp was 194 degrees. The fluid was sloshing out the top of the tube and covering the underside of the car in the immediate area. I noticed it after my third session when there was a puddle under the car. Not a ton leaked out, but enough to make me cancel my fourth session of the day, and there was a good coating on the tranny itself. i am using Amsoil Torque Drive ATF.
    Mar 2010
    San Jose, CA
    30
    979
    Quote Originally Posted by repenttokyo View Post
    Is it possible you were overfilled to begin with?
    Jan 2009
    1,171
    I don't think so - because I had the car on a different track a few other times in the weeks leading up to this event, and there was no leakage.
    Although - the track where it leaked (NHMS) has two big uphill sections, which could have caused fluid to spill if it was indeed overfilled...
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,213
    I don't know what the vent looks like other from an exploded diagram. If the vent will accomodate a rubber/plastic tube you connect it to an overflow tank. Canton Racing, among others, has overflow tanks that might work for this.
    PISNUOFF Guest
    Mine blows out of the breather tube on the street as well as the track. I haven't looked too much into it.
    Jan 2009
    1,171
    My biggest concern would be blowing out enough to jeopardize the proper lubrication of the transmission. Should this be something I should worry about?
    Thanks for the overflow tank suggestion, Darkman.
    01Cummins is offline Cadillac Owners Member
    Dec 2011
    25
    Mine was blowing out of the tube on the freeway. I dumped a little fluid out of and extended the tube up the firewall to the top of the motor. We will see what happens...
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Remove the tube and replace it with a hose and catch can this way ur not spillin oil
    crjim is offline Cadillac Owners Member
    Jun 2014
    1
    I have a 2008 awd and just noticed it myself. During "brisk" driving it is pushing out of the breather and falling down to the exhaust. Obviously this is not good, but how bad is it?
  15. Remove Advertisements
