Page 7 of 7 FirstFirst 1234567
Results 91 to 102 of 102
Thread: V1 E-Force Thread
  1. #91
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    Re: V1 E-Force Thread
    That's awesome! I'm excited too! Curious, did you go with cathedral or rectangular ports? I'm trying to come up to speed on this.
  2. #92
    tommy compton's Avatar
    tommy compton is offline Cadillac Owners Connoisseur
    Automobile(s): 06 CTS-V
    Mar 2007
    tha peg
    2,497
    Quote Originally Posted by philistine View Post
    Cathedral ports, I have AFR heads, so no getting rid of those.
  3. #93
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,208
    Are you gonna paint it yellow?
  4. #94
    Mar 2007
    tha peg
    2,497
    not likely, not sure it would look as good as the whipple.
  5. #95
    07cadv's Avatar
    07cadv is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2014
    Ft Rucker Al.
    329
    That is a sweet looking setup. Wish I had the cash laying around to do one.
  6. #96
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Can't wait for the writeup Tommy....that looks phenom!!
  7. #97
    LumberjackHering's Avatar
    LumberjackHering is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Nov 2013
    Jacksonville, NC
    27
    20
    Now I have all this money and I'm waiting for the e force to be finalized.
  8. #98
    grocerygetter's Avatar
    grocerygetter is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V
    Apr 2014
    AR
    41
    1
    I emailed them, he said it is ready to go and shot me pricing.
    What shop is it? Sk speed? I asked him and I can post here too...is this kit turn key complete other than fabbing an air intake tube? With fuel system? ...just need a custom tune?
    I would be in if I could order it turn key plus sort this stuff out to order myself:
    - Standard LS1/LQ4-9/L33 valley cover. You will have to drill the bolt holes so the counter sunk bolts can be installed.
    - Must upgrade to the LS2 Throttle body/harness
    - Must upgrade to the '06 - '07 strut tower brace. Have no idea if the '09+ will fit our application.
    - Use a brass 3/8" NPT street 90* (re-threaded to fit the block) for the oil pressure sensor.
  9. #99
    2007V is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V, maggie
    Apr 2011
    85
    Do you know the blower PN for retangular port heads?
  10. #100
    cutter5o is offline Cadillac Owners Member
    Sep 2009
    Houston
    47
    85
    Quote Originally Posted by grocerygetter View Post
    I can take a picture of my intake setup. Its pretty easy. I used some marine exhaust elbows and 4 inch pipe. I think its stainless. Ill look up the elbows and post the part numbers if I can find them
  11. #101
    Sep 2009
    Houston
    47
    85
    http://www.jamestowndistributors.com...SGkEsFePD_BwE#
    You have to trim the elbows some. The red stuff is plastidip I still need to work on removing. I sprayed it to show where I had to carve up my hood so it would close over the throttle body and supercharger
  12. #102
    Sep 2009
    Houston
    47
    85
    Also if your doing the E-Force and you plan to upgrade beyond the stock pulley then it is recommended that you do the following fix to the fuel rails. As shipped the fuel feeds one side of the fuel rails, crosses the front and then dead heads on the other side. When more fuel is required after upgrading the last two cylinders are starved for fuel. Jannety racing came up with a solution for the Camaro guys. Its a Y fitting that feeds both sides of the rails with the crossover in the front. This is a list of the part numbers needed to make it work on the V kit
    FRA-371012 HOSE ASSY STR X STR ALUM NUT A $22.95 2 $45.90
    RUS-644020 ADAPTER FITTING A $11.95 1 $11.95
    RUS-650400 BILLET Y BLOCK A $17.95 1 $17.95
    RUS-670343 FITTING $13.95 1 $13.95
    SUM-220166B -6 O-RING TO -6 FLARE FIT BLK A $6.95 4 $27.8
    All parts ordered from summit to make the Y setup that connects to the E-Force fuel rails
  • You may not post replies
