Need Help again! 8.8 cv clearance issue!
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V Performance Mods Discussion, Need Help again! 8.8 cv clearance issue! in Cadillac CTS-V Series Forum - 2004 - 2007; Ok so the passenger side cv goes in fine. The driver side not so much. It hits in two spots. ...
    nikdsctsv is offline Cadillac Owners Fanatic
    Automobile(s): none
    Jul 2009
    32
    139
    Ok so the passenger side cv goes in fine. The driver side not so much. It hits in two spots. One on the left side (as you are looking toward the cv) against the sub frame. The second is hitting on the head or the lower control arm bolt. Both are hitting simulanteously and not allowing the cv to pass and be installed!?
    Has anyone ran into this? the fix?
    I will be searching this diligently right now, since I'm kinda F*ked being a holiday weekend for any support from CS.
    Thanks
    Sweetwilliebrownjr is offline Cadillac Owners Member
    Automobile(s): 06 cts-V
    Jun 2012
    Brandon, ms
    36
    60
    Re: Need Help again! 8.8 cv clearance issue!
    I believe you put the a les in before bolting the diff up. That way you can move the diff to get the a les through.
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    lift the diff higher then it shouild be mounted. install the ds axle and drop it into place.. this instruction is deff in the 8.8 thread i posted about it with pics
