Needed: Stock rear shock top mount (for upgrade design work by Vorshlag Motorsports) - Page 6
Page 6 of 7 FirstFirst 1234567 LastLast
Results 76 to 90 of 92
Like Tree12Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Needed: Stock rear shock top mount (for upgrade design work by Vorshlag Motorsports) in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by sssnake I am interested in these with or without the group buy. I didn't see these on ...
  1. #76
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Re: Needed: Stock rear shock top mount (for upgrade design work by Vorshlag Motorspor
    Quote Originally Posted by sssnake View Post
    I am interested in these with or without the group buy. I didn't see these on their webpage. Did I miss it or do I need to just call them?
    That's because they're not ready for purchase yet. The fitment is slightly off.
  2. #77
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    48
    291
    understood on the fitment issue. As you can see I am anxiously awaiting this part.
    DavidBoren likes this.
  3. #78
    Iceman_jd's Avatar
    Iceman_jd is offline Cadillac Owners Fanatic
    Automobile(s): 2007 3.6 CTS
    Oct 2012
    Arizona
    112
    Quote Originally Posted by FuzzyLogic View Post
    The good news is that the solution will be a perfect replacement for the OEM part and include all necessary hardware (Grade 8 / Class 10.9). You can help me out by expressing your intention to buy a set, if that's what you plan to do, so that I can get a headcount and we can get these parts delivered to your doorsteps in the next couple of weeks.
    Count me in Fuzzy.
    John (Iceman)
  5. #79
    Manofmetal01's Avatar
    Manofmetal01 is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V Kooks 1 7/8, Corsa, KW Var 3, Hotchkis sways
    Apr 2012
    Alberta, Canada
    183
    I'm in.
  6. #80
    DavidBoren's Avatar
    DavidBoren is offline Cadillac Owners Enthusiast
    Automobile(s): Volant, VMAX, RX catch can, tranny cooler... RIP
    Jul 2012
    Portland, OR
    31
    518
    When will these be ready to buy?
  7. #81
    Mar 2011
    2,045
    Quote Originally Posted by DavidBoren View Post
    They're virtually ready for purchase. Tom gave me the go ahead to start the group buy on this forum and LS1Tech, but neglected to include his asking price. As soon as I know, you'll see a new thread.
  8. #82
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    I'm in
  9. #83
    Mar 2011
    2,045
    Final production hardware is arriving Monday or Tuesday. Key changes include a new eyeball plate with a slotted bolt hole on one side (provides correct fitment despite GM manufacturing tolerances), and shorter 1"-long, Grade 10.9, M10 bolts. At this point, most of the production CTS-V RSM parts will be borrowed from various Banski Motorsports' C4 Corvette RSM and toe rod kits, so I think this product should be readily available for a long time.
    Will verify fitment, update pictures, and start group buy this week.
  10. #84
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Fuzzy, in your opinion would changing the eyeball plate to 6061-t651 .25" aluminum be a viable alternative to steel?
  11. #85
    Mar 2011
    2,045
    Quote Originally Posted by Iceman_jd View Post
    That's an odd question. As far as I know, there's no advantage to aluminum in this application. Not only is steel cheaper, the weight difference is negligible, the plate is considered sprung mass, and the higher density of steel will provide better sound attenuation. Plus, with aluminum, you have concerns regarding galvanic corrosion between the plate and the low-carbon steel side bolts, as well as the constant spray of mineralized water, vehicle byproducts, salt, rocks, and anything else kicked up by the tires. I know that the CTS-V has cast aluminum control arms, but those don't get regularly blasted like the inside of the wheel well does. And the risk is justified by the fact that those components are considered unsprung mass.
  12. #86
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    I agree 100% with the choice of steel, galvanic corrosion aside and theoretically speaking just wondering if you think it would be strong enough and resilient to be used.
  13. #87
    Mar 2011
    2,045
    I think we're really getting into an academic discussion here, but generally speaking, aluminum should work fine if you use a thick enough plate to avoid plastic deformation under severe shock loads and reduce tensile stresses below the threshold necessary for Stress Corrosion Cracking (SCC). The idea of sudden, catastrophic failure of suspension components is a scary one, but SCC itself is a fascinating subject--I highly recommend reading the "Prevention" section of the associated Wikipedia article.
  14. #88
    Iceman_jd's Avatar
    Oct 2012
    Arizona
    112
    Bump: the group buy is going on now over at LS1 Tech
  15. #89
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    Any links to these for sale?
  16. #90
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,391
    If "these" refers to the subject of the thread, no, as far as I know Vorshlag never followed through on this.
    If "these" refers to the Banski mounts that the discussion moved to over time, you can contact them through their website.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
  17. Remove Advertisements
