T56 Bandaids Prepped - Ready to Rock!
Page 1 of 2 12 LastLast
Results 1 to 15 of 22
Like Tree1Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, T56 Bandaids Prepped - Ready to Rock! in Cadillac CTS-V Series Forum - 2004 - 2007; Parts List: PISNUOFF delrin/steel center linkage bushing (shifter side) UUC polyurethane side linkage bushings (shifter side) Azn2dmax fabricated center linkage ...
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Parts List:
    • PISNUOFF delrin/steel center linkage bushing (shifter side)
    • UUC polyurethane side linkage bushings (shifter side)
    • Azn2dmax fabricated center linkage arm
    • B-Quiet Ultimate damper to eliminate vibration in all three linkage arms
    • PISNUOFF brass center linkage bushing (T56 side)
    • Home Depot PVC side linkage bushings (T56 side)
    • Tremec #95 T56 bronze isolator cup
    • Tremec #52 T56 shift detent spring
    • Tremec #53 T56 shift detent ball
    • Carriage bolt
    If this doesn't result in a night and day difference in shift quality, I'll eat my socks. Stay tuned!
    Credit to Cadzilla for starting this whole thing and PISNUOFF and Azn2dmax for fabricating extra parts that you can't get anywhere else.
    jmsweetv likes this.
    mdleal is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Jul 2012
    Beaumont TX
    34
    44
    About how much do you have invested?
    Mar 2011
    2,045
    Re: T56 Bandaids Prepped - Ready to Rock!
    Quote Originally Posted by mdleal View Post
    In this mod alone? About $125, not counting the second generation Katech short shifter that I installed two years ago.
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    What does the Tremec spring and Ball fix? I missed those when I did all the upgrades!
    Mar 2011
    2,045
    Quote Originally Posted by etcts-v View Post
    Look up the Anti-venom mod for the T56. The detent assembly utilizes a captured ball and spring to give you that tactile "notch" going in and out of gears. The force required to push past that ball and spring is dependent on the strength of the spring, the condition of the ball, and (mostly) on the length of your shifter. Most people complain about the additional force required to shift following the installation of a short shifter, but they don't understand what's causing that other than the obvious loss of leverage. Now you do.
    Most of the time, when people complain about trouble shifting, the root of the problem is a transmission-motor misalignment (sagging motor mounts anyone?), but if they have a really short shifter, sometimes you really need to recalibrate the strength of the detent assembly by shimming it with one or two copper 13/16" washers. Finding a lighter spring really isn't an option, unfortunately, since the spring is an odd size. In some rare cases, that captive ball has gotten corroded or otherwise jammed in the assembly and won't spin any longer, which makes it even harder to shift than Tremec intended with the stock shifter assembly length. Emphasis on "rare." Since the parts are cheap, I figured I'd get in there and replace them while I have the transmission down.
    By the way, I'm sure I don't need to remind you, but take the opinions you'll find on the Anti-venom mod with a huge grain of salt. Some of the people that are reporting success are masking major transmission misalignments, and some of the people that are indifferent or entirely pooh-pooh this mod have stock length shifters. This is truly one of those situations where the statement, "your results may vary" truly applies.
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    : just ordered all revshift makes for the V but the flex disc, will follow this for sure as my shifting is not how i want it,hope all works out, keep pics and posts coming please.
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    49
    291
    I assume the B-Quiet is to reduce shifter rattle. I now have a few pieces of RAAM mat on mine. It helps.
    Mn800r's Avatar
    Jul 2012
    Scandia MN
    50
    383
    Quote Originally Posted by FuzzyLogic View Post
    Parts List:
    • Carriage bolt
    Are these in your parts pic?, if not where can a guy get some of these?
    Mar 2011
    2,045
    Holy mother of .... ! You win the award for the most deteriorated shifter bushings ever. Here's where you get new ones:
    https://creative-steel.com/store/ind...ct_detail&p=37
    FoD
    FoD is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Mar 2012
    Charlotte, NC
    250
    Seriously. Wow. Mine were bad, but nothing compared to yours. FYI, installation of the new bushings is a bitch without some sort of lube/grease.
    Mn800r's Avatar
    Jul 2012
    Scandia MN
    50
    383
    Will do good to know, when I do the cradle,Trans,trailing arm and motor mounts they will go in at that time.
    Faber is offline Cadillac Owners Fanatic
    Automobile(s): None :(
    Aug 2011
    Cincinnati, OH
    38
    407
    I did a few searches but the wife is getting on me to do some stuff around the house so I'm hoping you canhelp me out. Anyone have a picture of the bolt for the Anti-venom mod?
    Mar 2011
    2,045
    Quote Originally Posted by Faber View Post
    Really? I typed "anti-venom mod" into Google and all kinds of images came up. Took five seconds.
  16. #14
    Aug 2011
    Cincinnati, OH
    38
    407
    Thanks for the pic - I was searching "Anti-venom T-56" and kept finding forum references but no good photos showing where it was at. This morning took out the "-" and the picture you showed popped up. Ah the nuances of searching...thanks for finding that and sorry for being tarded.
  17. #15
    future_05_v is offline Cadillac Owners Member
    Automobile(s): 05 cts v
    Jul 2012
    Has there been any other updates on this mod?!
  18. Remove Advertisements
