Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: T56 Bandaids Prepped - Ready to Rock!
  1. #16
    jmsweetv's Avatar
    jmsweetv is offline Cadillac Owners Member
    Automobile(s): 2005 CTS-V
    Apr 2013
    Westfield, Indiana
    38
    37
    Re: T56 Bandaids Prepped - Ready to Rock!
    I will pay and handsome fee!!!!!!!!!!!!!
    Those parts look awesome and remember reading some threads about the pvc side linkage.
    Not to sound like an unappreciative impatient ***hole but i'm in when ya'll figure out price.
    Wish I had the ability to come up with something awesome to contribute...other than money.
  2. #17
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    That center linkage arm wouldn't work. I'd bet money on that.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  3. #18
    jmsweetv's Avatar
    Apr 2013
    Westfield, Indiana
    38
    37
    Quote Originally Posted by odthetruth View Post
    Can you explain more? I'm getting ready to drop my tranny and am trying to get all the info I can to get that last bit of slop out.
  4. #19
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Center linkage arm is too short from the first post. I wouldn't go that route with the linkage arm at all. Trust me. Everything else looks good.
    [2006 CTS-V]
  5. #20
    Mar 2011
    2,045
    I'm on travel, so I don't have much time to write, but suffice it to say that the center linkage arm in my original picture is not required and would not fit anyway.
    I wrote most of this up on the LS1Tech forums already, but to recap:
    - Based on Cadzilla's original thread on LS1Tech, I subjected te center linkage pin to extreme scrutiny. On my shifter, the pin barely moved in its hole, so I did not feel that welding it in place was necessary.
    - I replaced the plastic shifter cup with the #95 brass cup. Unless your cup is broken, it shouldn't have any effect on shifter slop. It is "merely" a durability upgrade.
    - I also evaluated the "Anti-Venom" mod. After looking at the shifter detent assembly and experimenting with several copper crush washers, I came to the conclusion that any deviation from the stock design would result in very sloppy shifting characteristics. My detent ball and spring were in excellent condition. If yours is seized, I would buy a whole new assembly instead of just the ball and spring, since it's not obvious how to service the detent assembly. I looked and looked for instructions to no avail.
    - The big two winners were the Home Depot mod and PISNUOFF's brass replacement bushing for the rear part of the center linkage arm. They really, really tightened up the shifter and added zero additional vibration. Advice: even though you only need four bushing pieces from Home Depot, buy 6-8. You'll find that their manufacturing tolerances result in some pieces that fit like a glove and others that are just a touch looser than you'd like. They're only like 48 cents apiece, so you can afford to buy a few extra. . Also, having a press on hand (e.g. a $30 bench vise) is very useful when it comes to jamming the metal cores from the stock rubber bushings into the PVC Home Depot bushings.
    - The Creative Steel shifter bushings are terrible. Get the UUC ones from Luke @ Lindsay Cadillac. I bought a set of Creativr Steel ones in advance to compare to my old UUC bushings and was stunned at how poorly fabricated and soft the Creative Steel units were. They might actually be worse than stock!
  6. #21
    jmsweetv's Avatar
    Apr 2013
    Westfield, Indiana
    38
    37
    So you will or will not gather these parts along with instructions for my lazy a$$ once you testing is complete?
    Nevermind, I guess I should have read the post all the way through. Thanks for the R&D! I already have Brian's shifter and center bushing along with the UUC bushings. I was hoping to try and clean up anything I could on the other end of the linkage.
  7. #22
    Mar 2011
    2,045
    Assorted pictures below. Sorry for the lack of proper chronological documentation--it started raining and I just wanted to get the effing thing finished.
    Fresh OEM center rear linkage bushing (goes into base of shifter) vs 7 year old unit
    View into T56 shifter assembly with no plastic or brass #95 cup installed
    Home Depot side front linkage rail bushings vs rubber OEM
    UUC side rear linkage rail bushings (installed) versus Creative Steel
    See these threads for a discussion of the pin and the brass PISNUOFF center bushing, plus everything else I talked about earlier:
    http://ls1tech.com/forums/cadillac-c...shifter-2.html
    http://www.cadillacforums.com/forums...ml#post2841048
  • You may not post replies
