REVSHIFT Rear Cradle Bushings - Page 4
Page 4 of 19 FirstFirst 1234567891011121314 ... LastLast
Results 46 to 60 of 280
Like Tree43Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, REVSHIFT Rear Cradle Bushings in Cadillac CTS-V Series Forum - 2004 - 2007; sooo whos breaking out the torch to install these hahaha MAKE A VID!!!...
  1. #46
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    re: REVSHIFT Rear Cradle Bushings
  2. #47
    Sweetwilliebrownjr is offline Cadillac Owners Member
    Automobile(s): 06 cts-V
    Jun 2012
    Brandon, ms
    36
    60
    I'll tell you another way that works pretty well, and the tools are more common. I've done a few this way. You'll have to drop the cradle prolly at least a foot. Get a hole saw, use it on the top of the bushing, and then do the same from the bottom. That'll get the rubber out, then you just USA a sawsall on the metal sleeve. Probably the easiest way without a torch.
  3. #48
    Revshift is offline Cadillac Owners Fanatic
    Automobile(s): none
    Apr 2011
    Warren, MI
    258
    Quote Originally Posted by Sweetwilliebrownjr View Post
    This is a great idea. It may also be the quickest way of going about it.
  5. #49
    Jun 2012
    Brandon, ms
    36
    60
    Yep. I'll prolly be putting mine in tomorrow. Got them Saturday, but haven't been back to work to use a lift yet.
  6. #50
    FoD
    FoD is offline Cadillac Owners Fanatic
    Automobile(s): 05 CTS-V
    Mar 2012
    Charlotte, NC
    250
    Wow. I still haven't received a shipping E-Mail yet...and I didn't order any of the brand new bushings.
  7. #51
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    40
    594
    Waiting for some feedback on these. I feel like if they don't work as good as planned your screwed. I don't think you can replace the stockers and then go with cradle bushings.
  8. #52
    Jun 2012
    Brandon, ms
    36
    60
    Yep, you're stuck with them, but can they really be worse than stock? Thats like saying paper towels are better to wipe your ass with than charmin. They do The job, but they leave a bit to be desired. Plus, a whole new cradle is not really that expensive.
  9. #53
    LS6Steve is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V
    Jun 2011
    San Jose, CA
    132
    I actually prefer a paper towel...
    Any feedback on an installed set yet?? Anyone?
  10. #54
    Jun 2012
    Brandon, ms
    36
    60
    Installed them today. Didn't even have to completely drop the cradle. I loosened the front 2 bolts, and took the rear bolts completely out, and let it drop down about 5 inches. I then drilled a hole through the bushing, then used a die grinder with a carbide burr, and shoved it in the hole, and used that to cut the sleeve. Then air hammer on the bottom flange of the bushing. Then, do the same for the front. All in all, not to bad. Maybe 3 hours total. Unfortunately I haven't been able to try them out yet, because I'm at work. I'll let yous guys know what I think in a day or 2.
    And the paper towel thing... That's just brutal. Charmin plus FTW!
    HAMSTAR and HAMSTAR like this.
  11. #55
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    Red or blue?
  12. #56
    Jun 2012
    Brandon, ms
    36
    60
    Blue. It's a dd. The rear is so much tighter in corners it's almost unbelievable. Slightly more noise, but the radio is always on anyhow. It's so unbelievably snappy when you take a quick turn! I can't get over it. Didn't get to try to dump the clutch, so I've no idea about wheel hop, but I had very little with the 8.8 conversion anyhow. These are a must!
  13. #57
    Mar 2011
    2,045
    Did you do the trailing arm bushings too? Where's the noise coming from--down low or up high? What kind of noise? Road noise? Bump noise? Sexy noise?
  14. #58
    Jun 2012
    Brandon, ms
    36
    60
    I did the trailing arm bushings about a week ago, and couldn't tell any difference in noise. The only noise I hear after the cradle bushings is just regular polyurethane bushing road noise. It could even just be placebo, because I expected it. It's not much at all. The radio turned up to about 2 notches drowns it out. I'm always jamming, so not even sure if it's louder, or I'm just paying more attention. There's also a sexy noise, but that's the magnaflows.
  15. #59
    Mrs.LS6's Avatar
    Mrs.LS6 is offline Cadillac Owners Fanatic
    Sep 2012
    SE Michigan
    32
    139
    I just got my car back from revshift on saturday. They installed rear cradle bushings, control arm bushings, new trans mount, sway bar bushings....actually EVERY bushing in the suspension has been replaced with their blue poly bushings. The car handles entirely different. Wheel hop is pretty much non-existent, corners are alot sharper and I notice the car reacts way more snappy and responsive in every aspect! I will be installing new tires tomorrow as well as an alignment so I'm sure it's going to feel another 100% different/better after that as well!
  16. #60
    Mar 2011
    2,045
    How's the noise?
  17. Remove Advertisements
