REVSHIFT Rear Cradle Bushings - Page 18
Page 18 of 19 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 256 to 270 of 280
Like Tree43Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, REVSHIFT Rear Cradle Bushings in Cadillac CTS-V Series Forum - 2004 - 2007; Originally Posted by Motown Cad Okay dumb question time. I'm good for those . Does directions come with the revshift ...
  1. #256
    DMM's Avatar
    DMM
    DMM is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2010
    Maryland
    40
    389
    re: REVSHIFT Rear Cradle Bushings
    Quote Originally Posted by Motown Cad View Post
    Okay dumb question time. I'm good for those. Does directions come with the revshift bushings? Because I'm trying to figure out and picture how you guys are doing this. Is the the whole rear cradle dropped from back of car or is being lowered a bit and supported and bushings being removed and replaced in a small place. Thanks.
    You really need to drop the cradle. The OE bushings are a PITA to get out. I used a recip saw with a coarse pruning blade to cut the rubber. Once the center was cut out, I used a metal blade to cut the outer shell of the bushing and it will drop out. DO NOT use the metal blade on the rubber...it won't do anything. You need as course as you can get.
    There is no easy way to do this, but it's one hell of a reward once finally done.
  2. #257
    runsfromdacops is offline Cadillac Owners Fanatic
    Automobile(s): twin turbo rear mount V1 CTS-V built 383. 875/860RW pump/met
    Oct 2011
    WA
    32
    177
    drop the cradlle, it will make it much easyr. i used a torch to heat the metal sleeve in the center until i could just push it out. then i used a sawzall to cut a slit in the outer sleave and folded it in on its self with a screw driver and puhsed it out
  3. #258
    incubusjunkie614 is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2011
    29
    drop the cradle, its easy! disconnect the parking brake under the drivers door. remove the the 10mm nut and the
    10mm bolt securing the e-brake line. remove the drive shaft, be sure to mark it. remove lower shock mount bolt. get a piece of wood and a jack under the diff/ subframe. disconnect the 2 brake lines one the right rear. get a helping hand or two, loosen/ remove 4 subframe bolts; 21mm and 24mm. lower jack. enjoy ease of bushing removal.
  5. #259
    Motown Cad is offline Cadillac Owners Fanatic
    Automobile(s): 07 Silver V Sport Susp.
    Jun 2011
    Southern MD
    51
    147
    Well thanks for clearing that up for me, I'm a little less dumb today now thanks. It's seems it's a fairly straight forward simple job but is a BIG JOB and the bushings can be a PITA. I like incubus' response "it's easy" Lol. Hopefully it could be done in 8 hours.
  6. #260
    Automobile(s): none
    Mar 2011
    29
    the cradle was the easy part! the bushings are a PITA and boy mine do not wanna leave!
  7. #261
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    Quote Originally Posted by Mn800r View Post
    Waiting for all this shit ass snow to melt so I can get it over on my buddy's hoist, will let u know.
    You doing motor mounts as well? Let me know how that goes as far as which headers need to be removed (assuming you have headers). Thanks! I've heard some conflicting answers on that. It's on my to-do list this summer.
  8. #262
    Automobile(s): none
    Mar 2011
    29
    motor mounts are a piece of cake with the headers off, even on the garage floor!
    {turn rant on} The more I dive into replacing everything it is becoming painfully obvious that replacing rear toe rods
    and all the rear bushings is no longer an upgrade, but a maintenance job. I have found most of there bushings to be
    torn/ripped or completely deflated and I found my toe rods to be bent, yes bet, way to go gm. {rant off} Now IM just excited to have a 2 ton go kart.
    Mn800r and Mn800r like this.
  9. #263
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    Quote Originally Posted by carlson_mn View Post
    Purchased all they offered in November...are these headers?
  10. #264
    Automobile(s): none
    Mar 2011
    29
    those are indeed headers...yes
    carlson_mn and carlson_mn like this.
  11. #265
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    These look like the same quality as the MM's which I have, so I'll be getting these.
    I have the BMR ones now and they didn't add to the normal noise, but when it's cold out they squeak all little bit.
    At least I don't have to remove my OEM cradle bushing turds again. Woooo!
  12. #266
    danrob0123's Avatar
    danrob0123 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 RAVEN CTS-V
    Oct 2009
    Long Island
    28
    191
    Revshift, will the front upper and lower control arm bushings be available soon? I've tried contacting you via your website and no reply.
  13. #267
    Automobile(s): none
    Mar 2011
    29
    fair warning! my cradle bushings were an absolute pain in the ass!!!! And that was with the subframe completely off
    the car. I dont know if it was the little bit of rust, the fact that gm/ jesus never meant for these to come out or what,
    but fair warning, expect a fight people. If you go in expecting a helluva fight and they fail out, be happy! All ranting
    it was nothing a big ass sawzall and a couple of air hammers couldn't handle. I would certainly recommend removing
    the center and then slitting the side, and folding it in, that seemed to be the best.
  14. #268
    Sigfod's Avatar
    Sigfod is offline Cadillac Owners Fanatic
    Automobile(s): 2006 CTS-V
    Oct 2010
    Sterling, VA
    169
    Quote Originally Posted by incubusjunkie614 View Post
    How many miles did the car have when you replaced these bushings?
  15. #269
    Automobile(s): none
    Mar 2011
    29
    car has 65xxx miles, and has never been driven in winter.
  16. #270
    Sigfod's Avatar
    Oct 2010
    Sterling, VA
    169
    Well then I am f'd
  17. Remove Advertisements
