Need some pretty urgent help with fender rolling.
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By garrettg
  • 2 Post By crankedupforit
2004-2007 Cadillac CTS-V Performance Mods Discussion, Need some pretty urgent help with fender rolling. in Cadillac CTS-V Series Forum - 2004 - 2007; I put on my TD Wheels yesterday and I am having issues with rubbing in the rear only when the ...
    xxxcrown Guest
    **Solved** Need some pretty urgent help with fender rolling.
    I put on my TD Wheels yesterday and I am having issues with rubbing in the rear only when the car hits dips or turning corners. I was not really stressing it because I can schedule to get the fenders rolled. Then it dawned on me that fender rollers are universal 5 lug which leaves me SOL with 6 lug. I am hoping someone here can shed some light on how to get the fenders rolled on our cars.
    I am running 275/35/18's. I think the problem is I had to use the small spacer in the rear to clear the hub properly with the TD wheel, and I didn't really take that into account when doing my research. Now I am barely too wide on the tire only when the suspension compresses. Hopefully you guys will have a suggestion for me.
    Thanks!
    tmonttt is offline Cadillac Owners Member
    Automobile(s): CTS
    Jun 2009
    26
    13
    Re: Need some pretty urgent help with fender rolling.
    I believe it was on another forum, but someone took a Eastwood fender roller, bolted it to one or two of the top lugs and just rolled the fenders based off of that. You might have to search around a little bit, but he said it worked out fine for his!
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    You shouldn't need to run a rear spacer with that wheel/tire combo, unless you just prefer the look? Was the rim or tire rubbing the trailing arm?
    rjoffe and rjoffe like this.
    xxxcrown Guest
    Quote Originally Posted by garrettg View Post
    Not true. Sean from Trinity Tek who sold me the wheels warned me that "some" ctsv's came with a little bit larger hub center section, meaning it pokes out a little further preventing the wheel from sitting flush. I believe this only applied to the wheels that have the center for center caps. He said there is no way to know if you have one of these cars until you try to bolt up these wheels. I tried to bolt up the wheels, they did not sit flush, I ordered the spacers from him and now they fit fine, just with a little rub sometimes.
    xxxcrown Guest
    I took a rubber mallet wrapped in cloth and just did it the old fashioned way. it turned out great and may have given me more clearance than if I used the rolling tool because I got the lip to curl back at an angle the tool might not be able to make. No more rubbing with the spacer and 275's.
    The tire tucks under the fender perfectly now when the suspension compresses.
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    http://www.youtube.com/watch?v=uXjL2G_QpjQ
    Also use a heat gun to stop the paint from cracking
    xxxcrown Guest
    ^I wouldnt do that, its a bit too sketchy for my experience. I hammered the lip flat and that seems to have done the trick for now.
    Jan 2009
    246
    Quote Originally Posted by GT|Motion View Post
    I also have a 07 and running center caps on my team dynamics. Are there really 3 versions of team dynamic wheels now, street(original allows for center caps/may require small axle cut), race(no center caps), and modified version(race modified by Sean for centercaps)?
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    Actually just shared this on LS1 Tech last week, here is a picture of how I did it, worked like a charm! Also run the heat gun on it just not too close and for not too long!
    Feb 2007
    Cheese land
    1,596
    OK if you think pounding on your fender with a hammer is better go for it. Most folks that do that wind up chipping the paint including several people on this forum. The bat trick has been around for years. But it's all good, if your method worked for you then mission accomplished
    etcts-v and etcts-v like this.
    etcts-v's Avatar
    Nov 2010
    35
    578
    Quote Originally Posted by crankedupforit View Post
    Agreed, don't bust out the rubber mallet! My roomate tried that while I wasn't looking and rippled the shit out of the sheet metal in one corner.
    xxxcrown Guest
    Its already been done, I did it yesterday. It is not as bad as you think, I have done this on several previous cars that I have owned so I have a little bit of experience with it. I know it sounds sketchy but the way the V's fenders are it is really pretty safe. I didn't chip any paint, nothing got dented, it turned out great.
    Also, just in case there is some confusion. I am not trying to flare the fender at all, the mallets purpose was solely to bend back that inner lip.
    Not sure, I just know he gave me a call and asked me if I wanted the wheels that could house the center caps, or the wheels that were for track only and can't house the centercaps.
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Those wheels look sexy. Since you're down here in southern Cali, I would imagine I will get to see them in person at some point. I want some black ones.
  16. Remove Advertisements
