What cam setup to make over 430hp
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 26
Like Tree3Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, What cam setup to make over 430hp in Cadillac CTS-V Series Forum - 2004 - 2007; Hey guys, I'm getting ready for a setup in the v. It's an 06 ls2 v and currently my tuner ...
    mike6466 is offline Cadillac Owners Member
    Automobile(s): 2006 cts v
    Jun 2012
    28
    43
    Hey guys, I'm getting ready for a setup in the v. It's an 06 ls2 v and currently my tuner is setting me up with a cam 228/231 114lsa. Said its a great cam but I'm not sure if its gonna break my goal in hp. It's gonna be getting long tubes, stock milled heads, port and polish on the heads, intake and full exhaust without cats. I've been thinking a lot about spraying the car and pretty site I will but I'd like to make over 430-450hp and then spray 150 and get close to 600.
    My question is will this setup break that or do I need something else. I got about 2000 to spend. Already have intake and exhaust so I have 2000 for pacesetter long tubes head job and cam setup.. Also I don't want the car to be super sluggish down low for dd
    Rakenjevnk's Avatar
    Rakenjevnk is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2011
    Calgary, AB
    35
    350
    Re: What cam setup to make over 430hp
    2000 will be cutting it close and chosing the cheaper route every time. Missing some supporting mods like lifters, new springs, ballancer, oil pump, timing chain...
    diff...
    axles...
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    If you're good with a wrench, you could do it for 2000, but just barely. Cam, springs, retainers, pushrods, etc. will run about 900. Catless OBX headers will run about 500-600, leaving 400-500 for a tune. If you're gonna have to pay for labor, well then...
  5. #4
    NC-V is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Feb 2010
    Mooresville, NC
    113
    Quote Originally Posted by HAMSTAR View Post
    ^^ there is ~2000 and that isn't including the head work you originally mentioned or any labor. Also as already stated, the extras while you're in there doing the cam: oil pump, new timing chain/set, lifters, new/underdrive balancer.
    That cam should suit you well for what you are looking for and with the entire package you should be at least close to the lower end of your numbers with decent driveability. These cars have a good deal of d-train loss especially with the stock clutch/flywheel. Not sure how far you are planning on taking the heads down, but if you decided to get much more aggressive (no lift numbers specified above) with the cam I would def. recommend checking PTV clearances.
  6. #5
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    what's the reason for replacing oil pump? just curious
  7. #6
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    Depends on mileage but mostly a "while you are in there" item and a chance to upgrade to a high volume unit.
  8. #7
    Apr 2012
    Seattle, WA
    731
    While you are in there, on cars this age, would you also change out the water pump?
  9. #8
    Jun 2012
    28
    43
    Guys don't worry I'm doing all the work. I built my cobra from the ground up with a built 9.5.1 motor for twin turbo, I know what I'm doing. I'm just trying to spec for a good cam. I have already even priced out all the parts like lifters springs etc.. And it's in my range. And pacesetters are not 500-600. I found them cheaper in the 370-480. I just need to know experience from others in cams in the v. Want something that's good for dd and spray and also good for lobe and to hit my mark.
  10. #9
    howanicm is offline Cadillac Owners Fanatic
    Automobile(s): 04 cts v
    Jan 2011
    Maui Hawaii
    25
    446
    Check amazon for pacesetters. I got mine on there for under $300 shipped. As for spray. I wish i could get nitrous in hawaii
  11. #10
    Jun 2012
    28
    43
    There isn't any there? Ill ship some too ya.. Haha
  12. #11
    Jan 2011
    Maui Hawaii
    25
    446
    No no2 in hawaii.. There isnt a big enough market here. There was one shop but they will only go get a big bottle to fill smaller bottles if they a minimum of 6 bottles. Just outta curiosity, how much is it to fill a 10 lb bottle out there?
  13. #12
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by mike6466 View Post
    FWIW, that looks somewhat like the cam my tuner is recommending for me, except he recommended to go with a tighter LSA. I think for spray, you want a bigger LSA because you want more cylinder pressure, otherwise you lose the benefit of the spray. So on that basis, this is a good cam. Wish I could comment by experience, though. If you've started another thread on another forum, please link to it here. Those dudes usually have some more technical comments.
  14. #13
    Jun 2012
    28
    43
    another forum?? What's another forum? I have it on ls1tech.
    I'm just wondering if I could go with a snl v2 or v4 cam and spray it and also be very street friendly. What's everybody's take in this cam? Anyone know te specs
  15. #14
    Jun 2012
    28
    43
    Or what's a big cam that's friendly with nitrous and dd
  16. #15
    2007ThunderV's Avatar
    2007ThunderV is offline Cadillac Owners Fanatic
    Automobile(s): 2007 cts v
    Jul 2011
    482
    lots of good cam choices out there.
    i have a tsp 233/239 on a 112 lsa that works for me, decent size cam, no surging ect. makes sweet power around 2700rpm
  17. Remove Advertisements
