Trans lash
Results 1 to 12 of 12
2004-2007 Cadillac CTS-V Performance Mods Discussion, Trans lash in Cadillac CTS-V Series Forum - 2004 - 2007; Does anyone know how much play there is supposed to be on the output shaft of the trans when the ...
    howanicm is offline Cadillac Owners Fanatic
    Automobile(s): 04 cts v
    Jan 2011
    Maui Hawaii
    26
    446
    Trans lash
    Does anyone know how much play there is supposed to be on the output shaft of the trans when the car is in first gear?
    Rakenjevnk's Avatar
    Rakenjevnk is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2011
    Calgary, AB
    35
    350
    Re: Trans lash
    I am interested as well, trying to figure out if it's rebuild time... hard to get into first from a stop and a vibe in 5th 6th...
    Keep thinking some gears, carbon fibre synchros, and brass shift forks be making things right
    Jan 2011
    Maui Hawaii
    26
    446
    I had replaced my rear end on sunday thinking that the excessive lash was that but now im thinking its either the clutch pp or fw is warped or broken springs on the clutch disk or the dreaded transmission being worn ha.
    Rakenjevnk's Avatar
    May 2011
    Calgary, AB
    35
    350
    Re: Trans lash
    Let us know what you find. How many miles on the car? Still have the dual mass terd?
    Jan 2011
    Maui Hawaii
    26
    446
    The car has jus about 67k. Its got a soec stage 2 clutch in it.
    Jan 2011
    Maui Hawaii
    26
    446
    Spec*
    Rakenjevnk's Avatar
    May 2011
    Calgary, AB
    35
    350
    Re: Trans lash
    Cool. It's too bad nobody is piping up about tranny lash... aka: Bump!
    soulja's Avatar
    soulja is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V Sedan 6MT, (Sold) 05 Maggie & 8.8 V1.
    Sep 2009
    Belleville, Mi.
    39
    509
    Re: Trans lash
    What rear end did you put in? If stock, you will still have some pinion lash. Should be minimal though. 67K isn't a lot of miles, unless the trans was abused.
    Jan 2011
    Maui Hawaii
    26
    446
    Its a stock rear end. I was just curious how much lash there should be in the trams cuz it moves about 1/2 side to side before i can hear it or feel it hit a gear.
    Hammar is offline Cadillac Owners Member
    Automobile(s): Cadillac CTS-V
    Mar 2007
    Illinois
    96
    Re: Trans lash
    Mine has a fair amount of lash... I've never measured it, but was startled by how much the driveshaft turns 'lock to lock'
    Hammar
    Maggied 2005 V
    Jan 2011
    Maui Hawaii
    26
    446
    Hmmm..must be normal then. Are you experiencing any clunk with the new diff setup?
    Mar 2007
    Illinois
    96
    Re: Trans lash
    Yeah, I've got clunk with the CSS 8.8" kit still, but each thing along the way has helped (new clutch, motor/trans mounts, rearend/driveshaft/axle kit).
    BUT..... I did some damage at the drag strip that isn't all the way sorted out yet. Got the axle fixed, but still have a wicked vibration at 35mph, and then ~60 and up. Might be a wheel bearing, might be carrier bearing, might be a driveshaft/diff/trans??? It's car speed based. Not sure that's related to the clunk, but both suck
    I suspect my trans is really showing it's age, I just turned 123k miles. Very few of them have been easy. Hope I can limp through till Spring.
    Hammar
    Maggied 2005 V
  15. Remove Advertisements
