uh oh, loud ticking from the right side of my engine
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 20
Like Tree3Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, uh oh, loud ticking from the right side of my engine in Cadillac CTS-V Series Forum - 2004 - 2007; uh oh, after a good day at NJMP, I'm hearing a ticking noise from the right side of the engine ...
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    uh oh, after a good day at NJMP, I'm hearing a ticking noise from the right side of the engine all through 2nd that speeds up w/ RPMs. In 3rd, it dissipates and I can't hear it any more after that.
    Bad gas or valve or...?
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,179
    Re: uh oh, loud ticking from the right side of my engine
    It could be nothing but a lifter taking time to fill with oil. However, given the propensity of LS6 springs to break, and the more infrequent tendency of the rocker arms to cough up needle bearings, I would pull the valve covers and look things over.
    Houdini's Avatar
    Houdini is offline Cadillac Owners Connoisseur
    Automobile(s): 2016 CTS-V, 2010 CTS-V 6MT (Sold), 2007 CTS-V (Sold)
    Nov 2007
    St. Louis Metro
    1,404
    LOL probably a long shot but check your spark plugs. I had one loose in my 07 and it ticked like crazy. The metal heat shield around the plug wire was also making noise from the vibration of the loose plug. Pretty hilarious.
    http://www.cadillacforums.com/forums...se-solved.html
    sssnake's Avatar
    sssnake is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    Dec 2008
    Huntsville
    48
    291
    Chasing a tick in my sons 98 WS6 and all I have to say is GOOD LUCK! Finding ticks in these things is like finding a needle in a hay stack.
    What I've done to date might help... Get a mechanics stethoscope and see if you can locate the sound (I haven't had much luck with this but it may help u narrow things down).
    Remove the valve covers like Darkman said and check rockers, rods, and springs.
    Check for exhaust leaks around the manifold.
    check all plugs to make sure they are tight.
    You may want to run it with belts off for a very short time to see if it is in one of the accessories.
    Pull the oil pan and check the pump and screen (obstructions to the screen or problems with the pump can cause a tick).
    Pull the heads and inspect/repair/replace the lifters.
    If absolutely all else fails you can pull the engine and check the crank, wrist pins, and connecting rods. I haven't gotten to this stage yet and hope I never do.
    I may have left a few things out but this is what I have found to date. I have also heard mixed reports about the harmonic balancer causing ticks. Currently we are at the oil pump stage but the tick is so loud I doubt it is the problem.
    PISNUOFF Guest
    It's curious that it goes away in 3rd. Like stated above, pull valve cover and check springs and rockers. Check plugs and wires and exhaust manifolds. Then pull the heads and replace lifters if the other items are ok. Pulling to oil pan is major work as the cross member won't allow it without basically pulling the motor.
    sssnake's Avatar
    Dec 2008
    Huntsville
    48
    291
    Quote Originally Posted by PISNUOFF View Post
    Can you release the motor mounts and use a cherry picker to lift the motor enough to gain access?
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    My injectors seem to be the source of some of my ticking. They are pretty loud
    PISNUOFF Guest
    There is less than an inch to start with and I think about 1.5" before the trans hits the tunnel.
    sssnake's Avatar
    Dec 2008
    Huntsville
    48
    291
    Gotcha
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    Thanks for the great replies - I think the trifecta of exhaust leak/check under the valve covers/check the spark plugs route is how I'll proceed.
    I'm not sure that this is the cause but I think it's an exhaust leak at the head. As I was PBBlasting my header bolts this AM to get ready for my Kooks install, I noticed... the front right bolt head on the stock manifold is already sheared off - somehow. The headers/heads have never been off... the "sheared" part of the remaining stud is still a bit shiny, so my assumption is that ???it sheared off while driving (hard)??? last weekend
    I'm still going to inspect the rockers/springs/etc.
    and I'm not sure it goes away deep in 3rd and beyond - it may just be I don't/can't hear it.
    Prentice is offline Cadillac Owners Member
    Automobile(s): 05 cts-v
    Sep 2009
    45
    55
    My same bolt was sheared off to.Ended up having to pull the head,i could never succsefully remove it with it on the engine.
    Hope you have better luck.
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    Good news - two days soaking with pbblaster and all the other header bolts came off w no problem. (The car only has 46k miles.). Vice grips worked on the broken stud as well. - told my wife I was the luckiest man in the world...
    I checked the plugs and under the valve covers and everything looks fine...
    Time to do motor mounts and put the kooks on tomorrow.
    Houdini, Houdini, shadybx7 and 3 others like this.
    crankedupforit's Avatar
    crankedupforit is offline Cadillac Owners Connoisseur
    Automobile(s): 05 CTS V 07 ESCALADE
    Feb 2007
    Cheese land
    1,596
    Noticed your sig JC. Let's see your custom brake ducting please.
  16. #14
    jclayc's Avatar
    Sep 2008
    SC
    43
    418
    I'll take pics tomorrow - driver's side uses a z06 duct and 3" hose. Passenger side has a 45 degree silicone elbow reducer 3" to 2" with 2" ducting around the wheel. Does ok with 275/35s...
  17. #15
    Feb 2007
    Cheese land
    1,596
    Quote Originally Posted by jclayc
    Thank you sir.
  18. Remove Advertisements
