ti brake shields
Results 1 to 10 of 10
2004-2007 Cadillac CTS-V Performance Mods Discussion, ti brake shields in Cadillac CTS-V Series Forum - 2004 - 2007; Considering getting ti brake shields now that i want to start tracking more and would like to get opinions as ...
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    29
    979
    ti brake shields
    Considering getting ti brake shields now that i want to start tracking more and would like to get opinions as to what thickness for these shield are sufficient and what is overkill? Start at 0.5 mm and go up by. 5mm to 2mm
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: ti brake shields
    Someone here used them on track, possibly bigjim. I assume you mean Ti shims to help stop the heat transfer between brake pad and caliper and lessen fade.
    I believe the thickness will depend on the pad and the slack inbetween. Some brands utilize as much material as possible. Thicker/newer pads would utilize the thinner and less thick or even used pads would use the thicker version.
    hardbrakes.com, tispeed and girodisc all have some that fit (I'd check with Luke to see if he can get the girodisc at a good price)
    Mar 2010
    San Jose, CA
    29
    979
    Yes I meant shims, sorry wrong terminology. I'm thinking maybe 1mm up front and .5mm in the rear might be sufficient for good heat dissipation.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,312
    I have some for the fronts, although I can't recall where I got them. I think they're probably 0.5mm, but they may be 1mm. As Junior1 said, new pads are going to make a thick shim impossible to fit, so I don't think I'd go any thicker than 1mm.
    Now that I've installed the V2 brakes, I won't be needing the V1 shims anymore. Right now they're in my household goods shipment, so I won't have them until I find a new place to live and get all my stuff delivered and unpacked. In the next few weeks I should have them.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    I run them front and back. Stoptech, 1mm
    Part nos.
    F: 68.180.1001 "D1001"
    R: 68.180.0592 "D592"
    Mar 2010
    San Jose, CA
    29
    979
    Quote Originally Posted by JDB View Post
    Part nos.
    Where'd you buy them?
    jclayc's Avatar
    jclayc is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Cadillac CTS-V
    Sep 2008
    SC
    43
    418
    JDB's Avatar
    JDB
    Apr 2010
    PA
    1,070
    Quote Originally Posted by OneFast V View Post
    I bought them used (new in the bag?...didn't appear to be used) from lunarx in the classifieds.
    Search the PN online and a bunch if Stoptech retailers pop up. I'm not sure if Stoptech are any better than what Hard Brake sells for less.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Quote Originally Posted by jclayc
    I've bought from these guys for both V1 and V2...
    Mar 2010
    San Jose, CA
    29
    979
    Quote Originally Posted by AAIIIC View Post
    Well if you'd like to hand them over... I will gladly take them
  13. Remove Advertisements
