Track tire size
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
2004-2007 Cadillac CTS-V Performance Mods Discussion, Track tire size in Cadillac CTS-V Series Forum - 2004 - 2007; Planning on doing my first track day in about a month. Been looking at getting some used Hoosier tires. Only ...
    Socer65 is offline Cadillac Owners Member
    Automobile(s): 2004 CTS V
    Jul 2012
    Atlanta
    9
    Track tire size
    Planning on doing my first track day in about a month. Been looking at getting some used Hoosier tires. Only problem is the size I can get them is a 245/35 r18. Anyone run a lower profile tire like this on a track? any issues? From what i heard from my CTS V buddies I shouldn't go this low. but the tires are $500 for the set with 75% tread left. Hell of a deal. I could keep looking for a set of 245/40 or 245/45 but i'd like to get them soon so I can get them mounted/balanced before i get too busy. Any advice is appreciated. Any thing else I should look out for before the track day besides obvious pads/fluids/oil etc...
    rjoffe is offline Cadillac Owners Connoisseur
    Jul 2005
    1,887
    Re: Track tire size
    http://www.ctsvparts.com/tire-sizes
    P
    lenty of us running 35 series tires.
    Ron
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: Track tire size
    275/35/18 for the used slicks (you may even find them cheaper) on Team Dynamic wheels otherwise on stock rims I ran 245/45/18 PS2's and PS SuperSports
    Jul 2012
    Atlanta
    9
    Re: Track tire size
    Thanks. I have the stock CTS V wheels to put these slicks on. I may try to stick with the 245's all around so I can rotate them, but if I was going to go wider in the back, what have you guys done with the stock CTS V wheels and hoosiers? would a 275 work okay? Im lowered on H&R springs.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,319
    Re: Track tire size
    Quote Originally Posted by Socer65 View Post
    I agree with your CTS-V buddies. I've run 245/40s, but 245/35s have a pretty low load rating. Might be pushing your luck.
    Quote Originally Posted by rjoffe View Post
    P
    Yes, there are plenty of people running 35 series tires, but I don't see a single 245/35 on that list. Am I missing something?
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    Jul 2005
    1,887
    Re: Track tire size
    Quote Originally Posted by AAIIIC View Post
    Just pointing out other combinations successfully used.
    Jul 2012
    Atlanta
    9
    Did some research. Max load on a Hoosier 245/35 is 992lbs. If I do this all around that a max load of 3968 lbs. this seems close to me. The Caddy weighs about 3800-3900 Lbs stock, plus full tank of gas and me and an instructor. Seems too close to be safe. Any input?
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Track tire size
    i run the Hoosier 245/35's. I try and keep my eyes open on the Hoosier discount site:
    https://www.hoosiertire.com/discontinuedtires.htm
    I scored my current set a long while back for $75/tire + 6 dolors shipping total (not each). There are deals to be had if you are patient.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
    Rakenjevnk's Avatar
    Rakenjevnk is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2011
    Calgary, AB
    35
    350
    Re: Track tire size
    Looks weak to me. Consider that when you corner hard all the weight of the car goes on the outer two tires equally if your a super master of driving. That means roughly 2000 lbs on each tire, double max load.
    Jul 2012
    Atlanta
    9
    Re: Track tire size
    Quote Originally Posted by Rakenjevnk View Post
    I'm with you on this. It seems too close to be safe to me. I'm gonna have to keep searching for a 245/40 size.
    Trukk. how many track days have you done on that tire? you run them on your 05 CTS V?
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Re: Track tire size
    HEck, on my cobalt SS I had beefier tires for daily use. I had some Hankook RS3 in 245/40r18 that saw street and track use. They werent as grabby as slicks of course but they weren't bad. And each one was rated at a hair over 1600lbs. So in a hard corner, one side could comfortably handle the whole car. Hell, I even got the inside rear cocked up in the air a few times.
    As much punishment as a track day throws at the car, having everything over spec'd is kind of nice insurance in my opinion
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    There are plenty of used tires from different places on the NASA forums. Plenty of 245/40 18s from what I remember...
    AAIIIC's Avatar
    Aug 2007
    6,319
    Re: Track tire size
    Quote Originally Posted by RyRidesMotoX View Post
    It is quite disappointing how limited the space is in our wheel wells. I get very jealous seeing cars that weigh a lot less than our Vs (E46s, STIs, EVOs, etc) wearing 275s and bigger with little to no work. It's no fair!
  16. #14
    Jul 2012
    Wildomar, CA
    31
    976
    Re: Track tire size
    I rubbed at full lock if I hit a bump, so I guess technically they didn't realyl fit very well. But on the track they were good.
  17. #15
    trukk's Avatar
    Jul 2004
    Elkridge, MD
    44
    6,063
    Re: Track tire size
    A couple of track weekends.
    You guys are overthinking this.
    -Chris
    2014 ATS: 2.0T-M6
  18. Remove Advertisements
