Interest in Delrin Cradle Bushings ? - Page 11
Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 151 to 164 of 164
Like Tree15Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Interest in Delrin Cradle Bushings ? in Cadillac CTS-V Series Forum - 2004 - 2007; I don't have the sets, he ships them. But what I'm saying is that the stock gap should be covered ...
  1. #151
    Junior1's Avatar
    Junior1 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 CTS-V Racecar, 2011 Escalade ESV
    Jun 2008
    About to pass you...
    1,248
    Re: Interest in Delrin Cradle Bushings ?
    But what I'm saying is that the stock gap should be covered up by the new bushing. Regardless if the bushing itself is thicker, it should all be flush once together. The bushing should sit flush up into the cradle all around and then the washer sits up against the other side of the bushing flush all around.
    If your washer is bending as you tighten it up then one side is getting hung up and not tightening up evenly
  2. #152
    jmargo is offline Cadillac Owners Fanatic
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    OK, did some more looking. As you can see the bushing is taller than the stock one. So when I tighten it down the middle of the stock washer has a gap and therefore deforms. The bottom picture is not fully seated so the gap is more pronounced. From how I understand you the delrin bushing should be in-line with the stock metal sleeve.
  3. #153
    Junior1's Avatar
    Jun 2008
    1,248
    So what you're saying is the washer is pulling into that void in the center and bowing the washer up on the edges? Is it happening on both sides or just the one? That would be the telltale sign because it may just be installed wrong.
    You'll have to drop it to make sure the tops and bottoms aren't reversed or vise versa.
  5. #154
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    Exactly....All four do this but the fronts are closer. Is there a difference between the top and bottom ? IIRC they were both the same.
  6. #155
    Junior1's Avatar
    Jun 2008
    1,248
    You got it. There are tops and bottoms. The tabs are different sizes to make up for the voids. My guess is they are just reversed. I can't remember which tab went where. Hopefully someone will chime in as to which ones go on top/bottom
  7. #156
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    When I installed mine, I don't remember there being an issue finding which was the top or bottom. I believe I test fitted both to ensure a good fitment. I used a jack to press the top and bottom together (tons of Prothane grease), put some anti-seize on that bolt and hand threaded it in there. Then I torqued it all down.
    I believe I installed the fronts first then the rears. I had to loosen the cradle in the front again to do the rears but the Delrin inserts were firmly seated and uniform gap all around.
    At no point do I recall the washer starting to go concave.
    The only difficult task I had (6/10) was making sure the Delrin stayed seated and uniform when I was pressing them together using a jack. They wanted to keep popping out and it made things really messy with the Prothane grease getting all over my parts. It was like trying to install an oversize o-ring - popping out all over the corners etc. Once they're in there and pressed firmly together, they stayed put.
    My suggestions would be to correctly identify the tops/bottom, take measurements of the Delrin thicknesses and compare that with the OEM rubber thickness. The top OEM rubber measurement might be difficult to access depending how much you are dropping it but the bottoms should be a piece of cake to measure.
  8. #157
    Junior1's Avatar
    Jun 2008
    1,248
    If its not top to bottom than it is front to back but I remember there was a reason for the different tabs...
    IIRC the big ones go into the front mounts and the smaller diameter ones go into the rear. It may take a bit of force to go into the soft section of the cradle as well. Just make sure they're aligned properly, ie the male tabs will index into the female portion of the soft bushings
  9. #158
    acv1081's Avatar
    acv1081 is offline Cadillac Owners Member
    Automobile(s): 2004 Silver/Ebony Cts-V 63K miles
    Oct 2013
    Iowa
    35
    23
    Looking to buy a set for my 04... my email is acv1081@aol.com Please tell me how much and where to send the paypal payment to. Thanks!
    Adam
  10. #159
    Junior1's Avatar
    Jun 2008
    1,248
    Quote Originally Posted by acv1081 View Post
    Adam
    Sent Adam...
  11. #160
    Junior1's Avatar
    Jun 2008
    1,248
    One set left and then they are gone...
  12. #161
    V-twin is offline Cadillac Owners Fanatic
    Automobile(s): 06 CTS-V w/ Katech headers, Magnaflow, short shifter
    Sep 2013
    Chandler, AZ
    35
    119
    Any 06-07 bushing inserts? How do these compare in performance to replacing the bushings with the revshift polyurethane, besides easier install?
  13. #162
    Junior1's Avatar
    Jun 2008
    1,248
    Unfortunately the 06-07 inserts were never made up...
  14. #163
    acv1081's Avatar
    Oct 2013
    Iowa
    35
    23
    I haven't had time to install yet and somehow I can't find the instructions that came with them... Is it possible to email me a copy to acv1081@aol.com? Thanks!
    Adam
  15. #164
    Junior1's Avatar
    Jun 2008
    1,248
    Adam
    Sent...
  16. Remove Advertisements
