Header Question (and more)
Results 1 to 3 of 3
2004-2007 Cadillac CTS-V Performance Mods Discussion, Header Question (and more) in Cadillac CTS-V Series Forum - 2004 - 2007; First off, I want to say this site is awesome. I've been lurking/reading for a while and I've found a ...
    ambull01 is offline Cadillac Owners Member
    Automobile(s): LS6 CTS-V
    Sep 2012
    Maryland
    1
    First off, I want to say this site is awesome. I've been lurking/reading for a while and I've found a wealth of information. The CTS-V is a
    new purchase and the dealership sucked. They refused to fix the power seats (both of them had no power) so I Googled power seat failure and this sit popped up. Turns out my power seat wire under the driver seat was rubbing against a metal bracket and shorted. The
    freaking fuse in the back seat was searing hot (I know because I was an idiot and tried to pull it). Anyway, fixing it was a seriously
    proud moment. I'm a total moron when it comes to automotive tasks.
    Now my questions:
    I have a tire pressure warning indicator on my dash. It's only reading the right side tires and the right rear tire reading is false (it's
    indicating 36psi). There's nothing on the left side. I thought it was the tire pressure sensors so I bought three of them and just replaced
    them yesterday (used the automotive skill center on a military base). It's still not picking them up so I just wasted $200. Do you guys
    have any ideas as to my next move? I know the sensors aren't really necessary since I'm not running run flats but the stupid warning
    indicator is getting on my nerves. I believe I read an older post on this site about pulling the fuse to stop the warning indicator. Would
    you all recommend that route if all else fails?
    My performance mods will be run of the mill. They will be: light weight flywheel, shifter (probably the modded stocker), shifter bushings,
    LS7 clutch eventually, cam (I have no idea what they do so I have a lot of homework to do), cam springs, CAI, rear diff/axle hop kit,
    and potentially new mufflers. I believe the car has Kooks headers currently (I had the car on a lift yesterday to change the tire sensors.A metal clamp on exhaust had "Kooks" on it). Should I get rid of the Kooks headers and get a smaller diameter header? The car currentlyhas Magnaflow headers but I'm thinking about taking them off. They emit a little drone that's driving me crazy. I'm thinking about getting
    Corsa mufflers instead. I'm never going to race on public streets but I would like to get from 0-60 in the the low to mid 4's. Will the
    above mods get me to my goal? Of course all the torque/horsepower in the world will be for naught until I master the manual
    transmission. I just learned how to drive stick about a week ago when I bought the car. Kind of embarrassing I know.
    Thanks for any and all advice/comments.
    AAIIIC's Avatar
    Automobile(s): '05 CTS-V
    Aug 2007
    Where the Navy takes me...
    6,224
    Re: Header Question (and more)
    Internet forum tip - You don't need to hit RETURN when you get to the end of the text box you're typing in. The forum will automatically wrap the words for us, and that way it will look normal for everyone else, regardless of what screen size we've got.
    Moving on...
    Quote Originally Posted by ambull01 View Post
    I have a tire pressure warning indicator on my dash. It's only reading the right side tires and the right rear tire reading is false (it's indicating 36psi).
    What do you think the pressure really is, and based on what? 36psi seems pretty normal to me.
    There's nothing on the left side. I thought it was the tire pressure sensors so I bought three of them and just replaced them yesterday (used the automotive skill center on a military base). It's still not picking them up so I just wasted $200.
    The car won't automatically pick up the sensors, so you haven't wasted your money - you just have to program the car to "see" the sensors. This site has all sorts of useful information on it (throw that one in your Favorites ), including this process to program the sensors with nothing but your key fob. It only takes a couple/few minutes to do it, or you can take the car to the dealer and let them charge you $50 or whatever to do it with their little programmer. I recommend doing yourself for free.
    I know the sensors aren't really necessary since I'm not running run flats but the stupid warning indicator is getting on my nerves. I believe I read an older post on this site about pulling the fuse to stop the warning indicator. Would you all recommend that route if all else fails?
    If all else fails, just remove all 4 sensors. After about 50mi or so the car will ignore the missing sensors and just show --- for all 4 wheels and everything else will work fine.
    No, there's no reason to do that. Is there a reason you think you should do that?
    The car currently has Magnaflow headers but I'm thinking about taking them off. They emit a little drone that's driving me crazy. I'm thinking about getting Corsa mufflers instead.
    I assume you meant Magnaflow mufflers vice headers? I don't believe Corsa sells their mufflers individually, so you have to buy their whole kit, which isn't cheap.
    I'm never going to race on public streets but I would like to get from 0-60 in the the low to mid 4's. Will the above mods get me to my goal?
    Maybe - right up until it you launch it hard to try to get that low 4sec 0-60 time and scatter the rear differential all over the road. This is not a car for stoplight drags to 60.
    '05 Stealth Grey CTS-V, 19x8.5/10" CCW T140s with Toyo Proxes T1 Sports (summer), black Team Dynamics ProRace 1.2 wheels with 275/35-18 R-compounds (track), Hyperblack Rota Torques (winter), KW Variant3s, V2 front brakes, Hotchkis rear sway bar, EPS cam, TEA-ported 243 heads, FAST92 intake w/LS2 TB, JBA Camaro/G8 1-3/4" shorty headers w/JBA cat pipes, Corsa exhaust, UUC motor and tranny mounts, UUC shifter, MAPerformance trailing arms, Specter cradle bushings, etc...
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    Do a tire program relearn, which would be like:
    # 1) key in RUN, engine off
    # 2) park brake set, cluster on pressure display
    # 3) press and hold BOTH the LOCK and UNLOCK SIMULTANEOUSLY for about 10 secs until the horn honks. (on the Keyless Entry remote)
    # 4) let air out of (or put air into) Left front tire until you hear another horn honk (only let the air our for about 3-5 seconds.... then be patient and wait for the honk... it could take up to 20-30 seconds before it honks)
    # 5) repeat on Right Front tire
    # 6) repeat on Right Rear tire
    # 7) repeat on Left Rear tire
    # 8) after left rear tire you should hear a double honk and the process is complete
    # 9) verify the pressures on the cluster display
    You can also hold a decent magnet to the pressure sensor on each wheel until the horn honk too instead of putting or releasing air, IIRC.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
