Is this normal?
Results 1 to 11 of 11
Like Tree1Likes
  • 2 Post By NC-V
2004-2007 Cadillac CTS-V Performance Mods Discussion, Is this normal? in Cadillac CTS-V Series Forum - 2004 - 2007; I noticed when coasting down a hill in second gear for about 30 seconds there is almost no engine brake ...
    howanicm is offline Cadillac Owners Fanatic
    Automobile(s): 04 cts v
    Jan 2011
    Maui Hawaii
    26
    446
    Is this normal?
    I noticed when coasting down a hill in second gear for about 30 seconds there is almost no engine brake and timing is advanced about 36* and throttle position is at 15-17%. After about 30 seconds timing is droped to about 6* and throttle position remains the same. Now there is alot of engine brake. I am still chasing the high idle while coastin in neutral issue and cant for the life of me find a vaccume leak..Im wondering if it is a job for the tuner. Thanks in advanced for the help.
    PISNUOFF Guest
    Re: Is this normal?
    That is DFCO and completely normal. It does it on flat land also, not only down hills.
    If you're chasing an erratic idle and you didn't change anything to make it change, there is a vacuum leak or a sensor issue. If you've modified things, it needs tuned. There are several parameters that effect it. Which ones to modify depends on what it's doing.
    Twitch's Avatar
    Twitch is offline Cadillac Owners Connoisseur
    Automobile(s): '05 CTS-V, '00 SLS, 98 SLS, 89 Eldo, '80 Eldo
    Mar 2006
    NYC
    46
    4,000
    Re: Is this normal?
    Yeah, sounds like DFCO to me too. Personally, I disable it below 4th gear. Too jerky if you have a passenger in the car.
    How high is the idle when coasting? It's normal for the idle to hang between 1000-1500 rpm then drop to normal as you come to a stop.
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Re: Is this normal?
    36 degrees of advanced timing? Isn't that really high?
    Jan 2011
    Maui Hawaii
    26
    446
    Re: Is this normal?
    Pisnuoff- I cant seem to find any vacuume leaks. I sprayed eather around every place that i thought could be leaking. Also if some sensor is bad shouldnt it throw a code? What bad sensors could be causing this type of behaviour? Thanks
    Twithc- It floats up to about 1800 rpm and stays there until i come to a stop. If i downshift on flatground it seems to carry me along there is no engine break unless im not waiting long enough. but then again shouldnt DFCO kick in right away?
    Since i noticed this high idle issue my fuel mileage went from just under 14mpg to about 11.9mpg
    NC-V is offline Cadillac Owners Fanatic
    Feb 2010
    Mooresville, NC
    113
    Re: Is this normal?
    howanicm: Like others have said, the "engine braking" you feel kicking in is the DFCO. It will not necessarily kick in right away, there are various parameters that need to be met for it to kick in like: Map values, Throttle position, Speed, Gear selection, Engine temp, etc. So it will kick in sometimes quicker than others depending on your tune/mods.
    Lollygagger: 36* isn't bad, especially under light load cruising or off throttle situations. There are cells in the stock timing tables with ~42+*, LS3s have upwards of 45*.
    Twitch: You may already be aware of this, but you can adjust the ramp in and out rates of the DFCO to "smooth" the engagement and dis-engagement. This makes it a lot more tolerable in lower gears and on the highway. I have it set on my personal V as low as 2nd gear down to 1100 RPMs.
    PISNUOFF and PISNUOFF like this.
    Jan 2011
    Maui Hawaii
    26
    446
    Re: Is this normal?
    Ok thanks for all the input guys i appreciate it. I am still new to all the tuning stuff but am trying to learn. Ill try to get you guys a video of whats going on so you can judge the issue for yourselfs.
    Thanks again!
    Jan 2011
    Maui Hawaii
    26
    446
    Re: Is this normal?
    I believe Darkman said when you push the clutch in the ecm kills timing, Does anyone know if it also tells the ecm to close the throttle?
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Re: Is this normal?
    Actually... in all honesty, a video isn't gonna tell most tuners much. Take a log with some tuning software and put it up here. Then we can tell you what's up. I am not a pro ass tuner by any means but I can look at a log and kinda get an idea of what may be wrong.
    Jan 2011
    Maui Hawaii
    26
    446
    Should i log,then make the problem happen or can you spot an issue with just a steady driving log? Also, i have a diablosport trinity. I realize these arent real popular around here. Will you be able to read the log i post even tho it was logged with a trinity. Thanks i really appreciate the help!
    Jul 2012
    Wildomar, CA
    31
    976
    Re: Is this normal?
    I have HP tuners so I can't read your log with the Diablo. I also have never used a Diablo tuner So I don't know what the capabilities are. Maybe someone with more experience with the Diablo can chime in.
  14. Remove Advertisements
