ATI Super Damper Install on LS2 V1
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 15 of 15
2004-2007 Cadillac CTS-V Performance Mods Discussion, ATI Super Damper Install on LS2 V1 in Cadillac CTS-V Series Forum - 2004 - 2007; Gentlemen, I ordered the ATI Super Damper, ARP bolt and Goodyear Gatorback belt online. They should all arrive tomorrow, in ...
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Gentlemen,
    I ordered the ATI Super Damper, ARP bolt and Goodyear Gatorback belt online. They should all arrive tomorrow, in time for a Sunday install.
    Here are the threads where I asked for advice and ultimately selected the ATI:
    http://ls1tech.com/forums/cadillac-c...ampner-v1.html
    http://www.cadillacforums.com/forums...ampner-v1.html
    I'm still in noob territory, though gaining knowledge by the day. I am about to ask many noobish questions, so I ask for your forbearance. I just replaced my radiator, so at least I know how to take that thing on and off now, lol.
    I rented a 3-jaw 5-ton puller from Autozone. I'm pretty sure this will work to remove the stock damper. However, what I am not sure about AT ALL is whether I need a special tool to install the ATI Super Damper. I simply don't have one. A friend of mine who's done a lot of work on LS1s seems to think that the extra length of the ARP bolt will be enough to catch the threads and pull the ATI on there, without the need for a special tool. Is that right? Will it work that way on the LS2?
    If I do need a special tool, does anyone know where I can get one?
    Many thanks,
    HAM
    jweymar's Avatar
    jweymar is offline Cadillac Owners Enthusiast
    Automobile(s): 05 Eforce LS3 V
    Apr 2008
    802
    Re: ATI Super Damper Install on LS2 V1
    I just put on the ATI 10% underdrive balancer. No special tool needed.
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    6,798
    Quote Originally Posted by HAMSTAR View Post
    Gentlemen,
    Here is the thread where I asked for advice and ultimately selected the ATI:
    Many thanks,
    HAM
    The biggest risk on reinstallation is stripping the threads inside the crankshaft. That occurs when folks try to pull the balancer onto the crank (interference fit) using the old crank bolt. This method works sometimes and sometimes it doesn't. When it doesn't work it strips the crankshaft internal threads because only some of the threads are engaged. Then you are in real trouble.
    The proper method is to use a tool (see the link below) which engages all of the crankshaft threads before the pulling-on process starts.
    http://www.coloradospeed.com/index.p...eviews_id=1082
    Some auto parts sell or rent these as part of a harmonic balancer kit. Another work around is to get some 6-7 inch threaded rods and add some nuts/washers.
  5. #4
    Apr 2012
    Seattle, WA
    731
    Thanks darkman, I called my local good* autozone and it looks like they have the actual recommended GM kit. We'll see if that's true when I pick it up.
    *lol, there is also a ghetto autozone that doesn't have shit and the clerks are jumpy from getting held up so much.
  6. #5
    Apr 2012
    Seattle, WA
    731
    Yeah, turns out they just had a generic install kit
  7. #6
    FuzzyLogic is offline Cadillac Owners Connoisseur
    Mar 2011
    2,024
    You mean the one on the left?
  8. #7
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by FuzzyLogic View Post
    that's it, the one you mentioned on the other v forum
  9. #8
    Mar 2011
    2,024
    Well, if you truly want to get this thing done this weekend and you're willing to eat the $50-60, you can modify that kit to work.
  10. #9
    Apr 2012
    Seattle, WA
    731
    Yeah, I'm gonna go for it. Will give you a call in a second.
  11. #10
    Apr 2012
    Seattle, WA
    731
    I had trouble getting the pulley off with the rented autozone puller, so bought an OTC puller recommended by C5 guys, and it worked like a charm. Stock puller came off like a knife through butter. Easy.
    Fuzzylogic has been coaching me through the install, and I owe him a couple of beers, to say the least.
    Question for anyone out there who has used an ARP crank bolt. There is conflicting information on whether to use red loctite or "ARP moly lube". What did you use, and why? I want to get this done tomorrow, don't want to order special lube and wait for it to ship, etc. Can I replace it with something else?
    For what it's worth, the ATI Super Damper instructions say to use red loctite with the ARP bolt. My worry is that this will lead to a bolt that impossible to undo in the future. Is that possible?
  12. #11
    darkman's Avatar
    Nov 2005
    Spring, Texas
    6,798
    The advice on the ARP crank bolt does vary all over the lot. My research indicates that: (a) you do NOT use red Loctite; (b) you can use either the ARP lube or motor oil (some say 30wt. others are non-specific); and (c) the target torque is 240 foot pounds although many report having to "settle" for whatever they could achieve as long as it was over 200 foot pounds.
  13. #12
    Apr 2012
    Seattle, WA
    731
    The advice for red loctite and 250lb-ft comes from the ATI instructions, not from ARP. Does that make it sound any more authoritative to you? ATI (unlike ARP) is known for precision.
  14. #13
    darkman's Avatar
    Nov 2005
    Spring, Texas
    6,798
    I don't know the basis for ATI's recommendation. I think Red Loctite and 250 foot pounds of torque is a recipe for a permanent, irreversible installation. I cannot confirm that because I am unable to find any cases where someone actually reports using Red Loctite in that application. I have seen an occasional reference to using some Blue Loctite without any follow-up report as to how it worked.
  15. #14
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by darkman View Post
    I have the same thread going on another forum. A member replied to say he uses red loctite and has had the bolt off and back on for an installation, without problems.
    http://ls1tech.com/forums/16682624-post29.html
    I'm not trying to be disbelieving or anything, you always give solid advice. I just wonder whether, since this ATI balancer has more rotating mass than stock, the red loctite is called for.
  16. #15
    darkman's Avatar
    Nov 2005
    Spring, Texas
    6,798
    My advice in this case is based on hear-say, and we have already established that the internet is full of conflicting hear-say on this one. The ATI instructions, coupled with the report that it can be removed is probably good enough.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
