How do you fx the "clunk" when you shift?
Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
2004-2007 Cadillac CTS-V Performance Mods Discussion, How do you fx the "clunk" when you shift? in Cadillac CTS-V Series Forum - 2004 - 2007; I've read many times where the clunk was a side effect of the design. Is there any option to get ...
    madramper is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    May 2012
    Alloway, NJ
    37
    34
    I've read many times where the clunk was a side effect of the design. Is there any option to get rid of it? It bothers me to the point where I am seriously considering dropping the $5k for an 8.8 rear conversion. My car only has 22k miles on it. Sometimes I get the clunk just from no throttle cruising and getting back on the gas. What can I do? I love the car, but this is driving me nuts!
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Re: How do you fx the "clunk" when you shift?
    That's the motor mouts. Replace em! I jut took out my turds for UMIs-- clunk is GONE!
    May 2012
    Alloway, NJ
    37
    34
    Thanks! I'm going to order some tonight!
  5. #4
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,155
    When new, my V exhibited very little clunk. At 26k miles, the clunk is only really evident when i first start to back up or when I start to go forward after having been in reverse. I think the clunk can remain tolerable if you are willing to replace the oem motor mounts and differential bushing from time to time. At high mileage, the dual-mass flywheel, which is a spring-loaded device can become an issue as well as parts of the driveshaft.
    I have considered the aftermarket differentials, but I don't drag race the car and $5k-$8 buys a lot of motor mounts, differential bushings, and even a replacement differential or two.
  6. #5
    jmargo is offline Cadillac Owners Fanatic
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    My 2004 has about 22K and the clunk....Just did the 8.8 conversion and guess what ? No clunk, super smooth even with light throttle in parking lots.
  7. #6
    May 2012
    Alloway, NJ
    37
    34
    Quote Originally Posted by jmargo View Post
    How do you like the conversion? Did you install it yourself? Any issues?
  8. #7
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
    IMHO, you can replace all the MMs and bushings and FWs and clutches and so forth you want, but until you replace the diff itself, you got the clunk.
  9. #8
    KB V is offline Cadillac Owners Member
    Apr 2012
    Orlando
    85
    Quote Originally Posted by darkman View Post
    How much should we expect to pay for a dealer installed diff? I'm not going to go to the track, but I may punch it from the stoplight. Will the factory diff eventually whine from this type of driving? I'm leaning to the 8.8. Plus, bushings and mounts may be cheap, but the install labor won't help the cause (kooks).
  10. #9
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,155
    Quote Originally Posted by KB V View Post
    I have not priced a differential lately but the last time I did the part could be had for $1,400 or so. Having installed my own axles I would probably install it myself, although I have a local shop that probably would probably install it for $300 or so.
    In the context of spirted driving but with no banzai launches or power shifts, the oem differentials are more likely to fail by developing an intolerable level of whine than by breakage.
    The only way to eliiminate 100% of the clunk and the possibility of whine-related failure is install one of the aftermarket setups.
  11. #10
    Apr 2012
    Seattle, WA
    731
    Easy guys. He has clunk and it seems he hasn't even replaced the stock mounts. First thing to do is replace the mounts and diff bushing with aftermarket, then reassess. If he's like me, he may not have any clunk AT ALL left after doing mounts and diff bushing.
    OP, do the easy stuff first. Mounts and CS diff bushings are a no-brainier.
  12. #11
    Scott2012's Avatar
    Scott2012 is offline Cadillac Owners Fanatic
    Automobile(s): 2010 AWD CTS
    Jul 2012
    Minnesota
    40
    261
    I've been enjoying my V for the past few weeks. It has 75k approx all stock.
    I have the clunk going slow shifting from 1st to 2nd. There is a very very slight shimmer when he car turns off.
    The clunk seems to go away after the car warms up, and if I shift fast and let the clutch easy between 1st and 2nd, it's fine.
    So, in your opinion should I get new motor mounts, rev diff bushing and a trans insert?
    And I have research this site and have found a lot of great info regarding DIY for hose items. But, recently I was in a motorcycle accident and won't be very mobile for a few months, so I may just have a dealer install these... Any ideas how long these would take a dealer to install? Just want to make sure if I go that route, I have an idea what they might quote.
    Thanks!
  13. #12
    Automobile(s): 04 V
    Dec 2011
    Nor Cal
    169
    Quote Originally Posted by madramper View Post
    I was very happy with the conversion. This was the first major work I did to the car and was able to do the job in about 6 hours. With help I can see this done in about 4.
    Quote Originally Posted by HAMSTAR View Post
    At 22K on the ODO the stock parts should still be good unless he beats on it.
  14. #13
    May 2012
    Alloway, NJ
    37
    34
    Thats what I was thinking. Especially with something like mounts. This is my first non-ford performance vehicle. The Fords will last well over 100k, so I guess it never crossed my mind. It looks like the mounts were a weak spot on these cars. I did order a set of motor mounts and a tranny mount, so we'll see what that does before I drop money I don't really have so I can drive the car I love frustration free!
  15. #14
    Apr 2012
    Orlando
    85
    Didn't mean to jump ahead.... I've got the "clunk and whine"(somebody get me a doctor!). I know the original owner had 1 mount replaced(only 1 then he sold it) at the dealer for almost a grand! They told him it cost more b/c of the kooks headers. Not sure if there was an oil change and something else added to that bill. So, I'm thinking, do the whole thing, 8.8 & mms, at once and save a few bucks on labor. The pain is the waiting to get the $5+ k together!.......I did order the revshift trans insert since it will cost $0. to install.
  16. #15
    MotorMounts's Avatar
    MotorMounts is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black CTS-V
    May 2009
    Salem Oregon
    50
    400
    Not sure where where the "5K" price tag came from for the 8.8 swap, originally the full kit was $4500 + about $200 for shipping. Right now the kits are $4050 + $200 for shipping. So that's only $4250 sitting on your door step.
    Have a look at our website for what the kit includes. The whole kit is a bolt in project, in fact you could use the factory service manual for the installation.
    Take a deep breath everybody, feels good. Peace Out
    Our phone number is 503-316-1811 We're here M-F, 8-5 Pacific Time.
    http://www.creative-steel.com
    maxx@creative-steel.com
  17. Remove Advertisements
