$hit just got real! - Page 4
Page 4 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 LastLast
Results 46 to 60 of 172
Like Tree37Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, $hit just got real! in Cadillac CTS-V Series Forum - 2004 - 2007; Since you did not mention wipe pattern - On the Yella Terras you are supposed to check the wipe pattern ...
  1. #46
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,155
    Re: $hit just got real!
    Since you did not mention wipe pattern - On the Yella Terras you are supposed to check the wipe pattern on top of the valve before establishing pushrod length. You add or subtract shim thickness to get the wipe pattern set. (There are threads/pics on other forums that show what the wipe pattern should look like. Generally, it is a thin line through the center of the valve.) http://forums.corvetteforum.com/1563994999-post1.html
    On the range of lengths your are getting - with my Trickflow 215s milled to a 61.5cc chamber, Jesel Shaft mounts, and EPS cam (base circle 0.0500 smaller than oem), and Morel lifters I use 7.367 (actual) 7.350 gauge length. The Morels require a 0.050" longer pushrod than LS7 lifters, so I would have been at 7.300 gauge or 7.317 (actual) with LS7 lifters. You setup is different obviously, but it does show that with aftermarket heads, etc. the length changes.
  2. #47
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by darkman View Post
    We did sharpie the top of the valves and then see where the rocker head was sitting and it looked like it was right in the middle of the valve or just slightly above the middle. I should've said that. My local speed shop guy told us to use the shims regardless, so we never measured without them. Obviously I'll need to try with and without.
  3. #48
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,155
    Quote Originally Posted by lollygagger8 View Post
    Sounds like you are on the right track.
  4. #49
    Apr 2008
    Indiana
    4,913
    I'll do it again and take pictures this time. Thank you for the link to that Darkman.
    I was wondering where to setup the dial gauge! It was pretty hard to get my fingers around the adjustable pushrod too. Then I had to put a small screwdriver on the adj pushrod to hold it from spinning while I adjusted it.
  5. #50
    Apr 2008
    Indiana
    4,913
    Got my pushod length. 7.393 basically 7.400. I used the stock pushrods and measure preload with the dial guage and got .060 so now I can order some up.
    Next potential issue:
    So my old LS6 fuel rail has a fuel regulator on the fuel rail itself.....the LS2 fuel rail on the right does not. Am I going to have to add one? How does the stock LS2 one get regulated?
  6. #51
    FuzzyLogic is offline Banned
    Mar 2011
    2,045
    As far as I know, the LS2 is unregulated.
  7. #52
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,155
    You do not have to add anything. If I recall correctly that "regulator" is really just a "shock absorber" for minor changes in pressure. (The book calls it a fuel pulse dampener. There is a diaphram operated regulator on the return line/ fuel sender assemby.)
    The LS2 rail does sit on spacers (about 1/2 inch thick).
  8. #53
    rand49er's Avatar
    Jan 2005
    South Lyon, MI
    67
    13,803
  9. #54
    NC-V is offline Cadillac Owners Fanatic
    Automobile(s): '05 CTS-V
    Feb 2010
    Mooresville, NC
    113
    This is correct, That is just a "pulse" damper. And as said already, you will be fine with the ls7 lifters, and those pushrods will be overkill for sure, we run standard comp hardened 3/8" pushrods in our lsx 454R builds (750+ HP NA, fairly large, steep cam) and spin that up above 7250rpms with no valvetrain issues (jesel shaft rockers and titanium valves)
  10. #55
    Apr 2008
    Indiana
    4,913
    Thanks man.
    Is this what you mean when you say the fuel rail sits on spacers?
    I'll try and find some at a hardware store. Fast wants too much for those bolts/spacers
    Quote Originally Posted by NC-V View Post
    Thank you. I was sweating the LS7 lifter thing as Mamo was trying to give me $hit for using them.
    My speed shop guy wants to sell me 5/16" (.120 thicker wall) Hardened Comp Rods for $120 +$8.40 tax= $128.40
    Mamo wants to sell me 11/32" (.120 thicker wall) Hardened Manton Rods for $210 +$15 shipping =$235.
    Should I just get 11/32' or 3/8" Hardened Comp Pushrods then?
  11. #56
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,155
    The spacers are about 1/2 inch thick.
    On my Trickflows I just had room for 11/32 pushrods but not for 3/8 pushrods. In making this determination (as indicated on the Manton website) it is okay for the pushrod to barely touch the head - effectively using is a "guide", but you must be sure there is no lateral pressure on the pushrod at the pushrod/head clearance point.
  12. #57
    Apr 2008
    Indiana
    4,913
    I'd rather not stack washers, but I guess I will if I have to.
    Maybe I'll just go with 11/32" then.
    Manton > Comp??? Or is it semantics/paying for the name at this point?
  13. #58
    darkman's Avatar
    Nov 2005
    Spring, Texas
    8,155
    I don't think Comp makes and 11/32 in LS engine pushrod based on my reading of their 2012 catalog. Do keep in mind Comp lengths are stated in "gauge" length while Manton's are ordered in actual length. (0.017" difference).
  14. #59
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Oh, the tangled webs we weave...
  15. #60
    Apr 2008
    Indiana
    4,913
    You are correct. Comp only goes up to 5/16...but I can get them at .120 wall thickness. So order em up??
    Plus I'd hate to have a problem down the road and have to order special pushrods.
  16. Remove Advertisements
