$hit just got real! - Page 3
Page 3 of 12 FirstFirst 123456789101112 LastLast
Results 31 to 45 of 172
Like Tree37Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, $hit just got real! in Cadillac CTS-V Series Forum - 2004 - 2007; ah yes, thats a straight piece, hold on, let me look for a 90 edit: http://intakehoses.com/Merchant2/mer...ry_Code=9DRESQ thats a 4.25 to ...
  1. #31
    Oh5V is offline Cadillac Owners Member
    Automobile(s): 1998 STS, CTS-V (sold)
    Apr 2010
    78
    Re: $hit just got real!
    thats a 4.25 to 4" 90degree elbow. then id still use the 4-3.75 insert. But wow, that elbow is 66 bucks.
  2. #32
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Balancer, timing chain, cam, oil pump all off. Time to put it all back together!!
    I bought LS7 lifters and a Melling oil pump
  3. #33
    Skidmarcx's Avatar
    Skidmarcx is offline Cadillac Owners Fanatic
    Automobile(s): NONE!
    May 2011
    Phoenix, AZ
    39
    356
    Nice man!
  5. #34
    Apr 2008
    Indiana
    4,913
    Thanks boss!
    Got timing chain, cam, oil pump, cover, balancer all back in and torqued. Some of the pan bolts were kinda difficult to get to, but not as bad as I was making it out to be. Praying for no leaks!
    Now time to clean the head surface on the block and get ready for some head
  6. #35
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    Wha happun?
  7. #36
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by thebigjimsho View Post
    Wha happun?
    This.....
    trukk, trukk, yooper and 1 others like this.
  8. #37
    Automobile(s): ZIP
    51,885
    Your engine is exposed. Does it run like that?
  9. #38
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Quote Originally Posted by lollygagger8 View Post
    Mamo wants me to buy some "semi limited travel race clip Johnson Lifters for $475...which I think is absolutely outrageous.
    I called my speed shop guy and he said 2110R (for LSx) Johnson Lifters are $395 for the set. Still crazy priced compared to an LS7 lifter ($140)
    With a "limited travel" lifter, you are either gonna have to make your PR length selection PERFECT, or will have to go with adjustable rockers. Neither of those options really appeals to me.
    In my V1, I'md having some stutter over 4.5k RPMs. I'm thinking it may be valve float: either a broken valve spring (I have duals), or a colapsed lifter. My max lift is .609, lobes are XFI/XER. Keep in mind this is after 70k miles. I should have probably swapped out my springs earlier, and I've never cracked the heads, and have 150k OEM lifters. Food for thought in your project.
    I will probabaly go with the Morel Link Bars (the middle of the road ones, not the 'street' (which are cast), and not the 'race', which are the limited travel and require adjustable rockers), since I'm captain overkill.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  10. #39
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by trukk View Post
    -Chris
    Well I ended up going with LS7 lifters since my speed shop guy got em to me for $140. I have to measure for pushrods now since I got the heads torqued and ready to plop em in. I hope the LS7 lifters are ok!
  11. #40
    trukk's Avatar
    Jul 2004
    Elkridge, MD
    44
    6,063
    There are things to worry about.....this ain't one of them.
    -Chris
    2014 ATS: 2.0T-M6
  12. #41
    Apr 2008
    Indiana
    4,913
    -Chris
    Right on man, thanks!
  13. #42
    Apr 2008
    Indiana
    4,913
    -Chris
    Should I spend the extra coin on the Manton 11/32" .120 thick Pushrods for $225 (Mamo's recommendation) or go with Manley 5/16" .120 thick pushrods for about $150? (speed shop's recommendation)
    I'm measuring for pushrod's tonight. So I'll be ordering soon!
    Side tidbit:
    Mamo says AFR's have 450 lb of open pressure. LS7 lifters are good to 475 lbs.....so I should be good to go.
  14. #43
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,207
    My vote (on how to spend your money, LOL) is for the Mantons. You cannot really get rigidity with hardness/heat treat alone, it comes from the diameter/wall thickness. The Mantons are great push rods.
    Edit: FYI _ If you determine the pushrod length using a Comp Cam adjustable pushrod, which is marked 6.80 inches, the answer you get in terms of pushrod length is "gauge length." Guage length is used by Comp Cams, Trend (which makes Comp pushrods) and some other pushrod sellers. Manton uses "actual length" which is 0.017 inch longer than gauge length. I do not know which unit of measure Manley uses.
  15. #44
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    578
    Fun build to follow, can wait to see your numbers!
    lollygagger8 and lollygagger8 like this.
  16. #45
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by darkman View Post
    Well my buddy who works for a machine shop and builds engines all the time, came over last night and we used his adjustable pushrod. We put the Yella Terras (using the "shim" which is just a washer) and tightened them down. We only got 7.325 on one and 7.33 on another.
    The directions in AFR heads say using roller setup you can be anywhere from 7.300 to 7.550 <-(I think that's the last number, I can't remember) But that seems awfully low to me. Does that seem right? We are going to try it again with a dial guage and see if different results present themselves.
    Ok, you talked me into it I'll get the Mantons as soon as I figure out the push rod length for sure.
  17. Remove Advertisements
