Ls7 clutch + tranny rebuild
Page 1 of 3 123 LastLast
Results 1 to 15 of 35
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ls7 clutch + tranny rebuild in Cadillac CTS-V Series Forum - 2004 - 2007; I have my ls7 clutch in and my tranny rebuild kit will be getting picked up tommorrow morning. This job ...
    stepchild21's Avatar
    stepchild21 is offline Cadillac Owners Fanatic
    Mar 2012
    156
    I have my ls7 clutch in and my tranny rebuild kit will be getting picked up tommorrow morning. This job will be starting most likely the start of next month.
    Any tips and tricks or things to avoid before I begin !?!?
    I have the directions from GMs "SI" (service information). Just looking for any bumps in the road that you guys have encountered.
    Thanks for any info and help !!!!
    CadzillaTN's Avatar
    CadzillaTN is offline Cadillac Owners Connoisseur
    Automobile(s): 2004 CTS-V
    Apr 2008
    2,061
    Can't help but good luck anyway.
    Is a transmission rebuild straightforward enough that someone could follow a detailed instructional and accomplish with unlimited time? I assume it's a skill that requires lots of experience.. which is the reason people get $1000s to rebuild.
    I've always wanted to attempt it based on videos I've seen. Other than there being 1000 parts and therefore 1000 ways to foul it up, what could go wrong? You always have the option to surrender, ship it off to RPM in pieces, and pray they don't charge you double to sort out the mess.
    runsfromdacops is offline Cadillac Owners Fanatic
    Automobile(s): twin turbo rear mount V1 CTS-V built 383. 875/860RW pump/met
    Oct 2011
    WA
    33
    177
    Re: Ls7 clutch + tranny rebuild
    the tranny rebuild is vary straight forward. pm me if you need any help. best tip i can give you is to lay things out as you take them out in oreder then dont touch the parts untill your going to replace/ reinstall them.
    Mar 2012
    156
    Okay perfect I'll definitly use a large table and set that all up. I'll MSG you if I run into any road bumps. Thanks for the help.
    Would you say the ls7 clutch is a noticeable difference over the oem?
    06BlackV is offline Cadillac Owners Fanatic
    Automobile(s): Cts-V
    Jun 2011
    28
    190
    Quote Originally Posted by stepchild21 View Post
    Most definitely different, cadillac should have put the ls7 clutch and flywheel in from tthe factory. It makes this car that much more fun to drive..😜
    Mar 2012
    156
    Perfect im glad I made the choice to go with it then. I bought the slave cylinder spacer to do te conversion but I hear using a ls7 slave cylinder could be better ?!? Are they pretty pricey or will the spacer work fine ?
    wcryan is offline Cadillac Owners Connoisseur
    Automobile(s): 07 CTS-V Maggied
    Aug 2009
    Escondido, CA
    28
    1,065
    use the slave cylinder. Then you don't need the spacer. Then also you dont have to worry about your slave going out since your already in there and have replaced it
    Mar 2012
    156
    Wheres a good place to get a slave cylinder ? And the ls7 slave bolts up with no mods ?
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    CoolRe: Ls7 clutch + tranny rebuild
    I should have my LS7 clutch,slave and Ram flywheel tomorrow with any luck, I bought the set up from here http://sdparts.com/brand/scoggin-dickey-parts-center The guy I talked to was very helpful, great to deal with.LS7 Clutch W/Ram Alum. flywheel, ARP bolts was $559.00 LS7 slave was $177.00 Pilot brg. around $16.00 shipping $15.00.
    Hope this helps and good luck!!
    Mar 2012
    156
    Okay perfect and that's the ls7 slave ?
    Mar 2012
    156
    Stupid question most likely but what's the "pilot brg" and should I also do that !??
    Aug 2009
    Escondido, CA
    28
    1,065
    pilot bearing...... If your in there you might as we'll do it just in case its gonna go out soon in your car. Don't wana pay all that labor again to have them take it apart. I think it's only around 20$
    Mar 2012
    156
    Well she's going in this weekend . Ls7 clutch. Ram aluminum flywheel. Ls7 Slave Cylinder. Tremec Master rebuild kit. Creative steel shifter bushings, and that should probably do it.
  16. #14
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    I made a big post over on the other site with tips on the clutch install, i suppose i should copy it over here sometime:
    http://ls1tech.com/forums/cadillac-c...tall-tips.html
  17. #15
    carlson_mn is offline Cadillac Owners Enthusiast
    Automobile(s): Platinum 06 CTS-V, kooks, magnaflow
    Jul 2012
    MN
    34
    636
    Sub'd for updates. Thanks for linky as well Dan.
    Also, anybody have a picture of this 'notch' that has to be made to the bell housing? I'd like a better idea of what needs to be done.
  18. Remove Advertisements
