Ls7 clutch + tranny rebuild - Page 2
Results 16 to 30 of 35
2004-2007 Cadillac CTS-V Performance Mods Discussion, Ls7 clutch + tranny rebuild in Cadillac CTS-V Series Forum - 2004 - 2007; That's an awesome guide !!! I didn't know you needed to notch out the bell housing to get this job ...
  1. #16
    stepchild21's Avatar
    stepchild21 is offline Cadillac Owners Fanatic
    Mar 2012
    156
    That's an awesome guide !!! I didn't know you needed to notch out the bell housing to get this job done. I told my buddy (tech whose doing this job for me) that it wouldn't need any altercations. But apparently it does !!! Haha
    How big of a notch ? Will he figure it out on his own do you think ?
    And how do you like your ls7 clutch setup ??? Big difference compared to the oem ? Or not so much??
  2. #17
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    507
    Re: Ls7 clutch + tranny rebuild
    He should be able to figure it out. It's just aluminum so cutting it is like a hot knife through butter. One square inch is about what it takes to enlarge the factory notch.
    Also, I love my LS7 clutch. No sacrifices, only improvement.
  3. #18
    Dan_Gurney is offline Cadillac Owners Fanatic
    Automobile(s): 07 - CTS-V
    Jun 2010
    Arizona
    407
    the notch is not bad. i cut down level with the flat ledge below the opening and the same depth back. be sure to round the back corner of your cuts to remove a potential stress concentration
  5. #19
    JFensty's Avatar
    JFensty is offline Cadillac Owners Enthusiast
    Automobile(s): 04 Blk Cts-V
    Oct 2010
    Allentown PA
    39
    594
    I didn't need to notch the bell when I did my ls7 install.
  6. #20
    Mar 2012
    156
    Yours fit fine without any modification ??
  7. #21
    JFensty's Avatar
    Oct 2010
    Allentown PA
    39
    594
    Yes. I got the tick bleeder and it had the 90* fitting on it. I had to straighten the fitting but that was it. I think I put a slight bend in the slave line so it didn't touch. Almost 15k since install and no issues.
  8. #22
    Jun 2010
    Arizona
    407
    You could probably bend the pressure line on the slave and make it fit, but it was more than i really wanted to bend it, the notch was easy to make with a dremel and was in an area that doesn't carry any load, but take a look at it when you get the parts and see what you think.
    It will require bending at some level to fit further up, but i was able to do that with several slight bends which i felt better about.
  9. #23
    Mar 2012
    156
    Okay that's great to know !!!! I just need to explain to my Tech where he's gonna need to make this notch approximately. To make this work. Or tell him to slightly bend it as he goes
  10. #24
    Jun 2010
    Arizona
    407
    I would just tell him he can notch it if needed and he should be able to see what he needs to do (either bend or notch), or decide how to work around it. Then if something goes wrong it is on his decision, and not because you told him to go one way or another.
  11. #25
    Mar 2012
    156
    Well I got a shit phone call today. All the gears in my tranny were pretty well f-Ed. So there was no point in a rebuild. New T-56 is ordered and on the way. Should be here end of next week.
  12. #26
    Mar 2012
    156
  13. #27
    RyRidesMotoX is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Raven, StainlessWorks header back exhaust
    Jul 2012
    Wildomar, CA
    31
    976
    Effed up how? Ground too many times or something? That sucks
  14. #28
    Mn800r's Avatar
    Mn800r is offline Cadillac Owners Fanatic
    Automobile(s): 11 V Coupe, 05 V Mod'd, 91 Fatboy,98 Ultra classic, 07 Tahoe
    Jul 2012
    Scandia MN
    50
    383
    Did you try to find a low mile used? What's a new one bringing? That does suck though, welcome to super car repair.
  15. #29
    Mar 2012
    156
    Apparently all the gears are pretty well screwed. Chewed right up.
    And unfortunately they're aren't many v's where I am, so pretty well mowers with used parts. So I just ended up getting a new one.
  16. #30
    Mar 2012
    156
    And we got it for 3500$. And still doing the ls7 swap.
    Tranny should be in next week !!!
  17. Remove Advertisements
