Results 1 to 12 of 12
Thread: What does the LS7 clutch feel like?
    QwkRhino's Avatar
    QwkRhino is offline Cadillac Owners Member
    Automobile(s): None
    May 2012
    O.C.
    40
    64
    I just bought a 2005 V 3 weeks ago. It has a Maggie Supercharger and aftermarket shifter. So far I love the car but finding it hard to drive it smooth when just cruzing. Kind jerky down shifting and I'm feeling like I really have to think about driving it smoothly. Yet the motor feels to have a great power band. Thinking it has to be the clutch my old 95 Z28 drove a lot smoother.
    QwkRhino's Avatar
    Automobile(s): None
    May 2012
    O.C.
    40
    64
    Will this mod help driveability ? Will it work with the Maggie supercharger?
    soulja's Avatar
    soulja is offline Cadillac Owners Enthusiast
    Automobile(s): 2009 CTS-V Sedan 6MT, (Sold) 05 Maggie & 8.8 V1.
    Sep 2009
    Belleville, Mi.
    39
    509
    Re: What does the LS7 clutch feel like?
    When you down shift, do you rev match? If not, start and it will be much smoother, but to answer your question. The biggest difference I felt when I put in my LS7 is faster revs, that help with quick rev matches and heal toe shifts. Also, no clunky up front, but still clunky in rear. Now that I have my 8.8 in. No clunky at all.
  5. #4
    OneFast V is offline Cadillac Owners Enthusiast
    Automobile(s): 2005 Raven Black CTS-V
    Mar 2010
    San Jose, CA
    30
    979
    check the motor mounts and differential mounts. you may need new ones.
  6. #5
    Rakenjevnk's Avatar
    Rakenjevnk is offline Cadillac Owners Fanatic
    Automobile(s): CTS-V
    May 2011
    Calgary, AB
    35
    350
    LS7 clutch was the best mod I have made to my car. The CS 8.8 makes it feel bullet-proof but the LS7 clutch makes it feel like a race(ier) car. Plus the turd seems to cause strange problems as it ages making the relatively cheap LS7 an even better upgrade.
  7. #6
    QwkRhino's Avatar
    Automobile(s): None
    May 2012
    O.C.
    40
    64
    Quote Originally Posted by OneFast V View Post
    Thanks everything stills feels and looks good with the all the mounts. I was just wondering it the LS7 clutch makes the car any easier to drive?
  8. #7
    Mar 2010
    San Jose, CA
    30
    979
    Quote Originally Posted by QwkRhino View Post
    The LS7 with the steel flywheel should have better driveability. That said with your maggie I'd consider an ls9x clutch
  9. #8
    trukk's Avatar
    trukk is offline Cadillac Owners Master
    Automobile(s): '05 CTS-V, '12 CTS-V Manny Vagon
    Jul 2004
    Elkridge, MD
    44
    6,063
    Due to all the rubber in the drive train, these cars are harder than most to drive 'smooth', unless you are *really* trying hard and babying them.
    -Chris
    2005 CTS-V:No Roof|T2+Eibachs|Corsa|UUC:Shifter, 2pc rotors, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hotchkis Sways|Kooks 1.75 Coated LTs+cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588+Dual Springs|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow OP|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Katech LS9X Clutch Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq
    2012 CTS-V:No Roof|Wagon|M6|Recaros|<-- SOLD
    2014 ATS: 2.0T-M6
  10. #9
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    507
    With a supercharger you're probably better of going with a clutch designed for more power.
    This car is almost 1000lbs more than the corvette it was intended for. The lS9x clutch is a good suggestion.
    I'd hate to see you get 20k miles out of an LS7 clutch and have to buy one all over again.
  11. #10
    PISNUOFF Guest
    I'd hate to see you explode the straps on three different LS9 pressure plates. Go with a strapless dual disc clutch.
  12. #11
    Mar 2010
    San Jose, CA
    30
    979
    Quote Originally Posted by PISNUOFF View Post
    What are you running now?
  13. #12
    NickL84's Avatar
    NickL84 is offline Cadillac Owners Member
    Automobile(s): 2005 Cts-V
    Jun 2012
    Boston, MA
    32
    39
    Quote Originally Posted by soulja View Post
    Soulja, what did you use for an 8.8 swap? Creative Steel or piece one together yourself?
  • You may not post replies
