Replace H&R springs with coil overs?
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 25
Like Tree2Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Replace H&R springs with coil overs? in Cadillac CTS-V Series Forum - 2004 - 2007; 1.jpg I'm looking into replacing my current suspension with coil overs. I have a 2004 V with H&R springs. I ...
    philistine's Avatar
    philistine is offline Cadillac Owners Enthusiast
    Automobile(s): Black 2004 CTS-V
    Sep 2011
    Birmingham, Alabama, United St
    821
    I'm looking into replacing my current suspension with coil overs. I have a 2004 V with H&R springs. I bought it that way so I can't compare how the car handled stock. The only complaint I have is that it sits a little too low for my taste- she's laying on the ground. I'm also having difficulties getting an alignment...dealership won't touch it and it's too low for most alignment shops. For anyone who wants to know how the H&R springs perform, it drives very nicely. It rides smoothly over rough roads and is very comfortable on the interstate. The tires have never rubbed and it grips tight around corners (Hotchkis anti-roll bars installed).
    So the question is...go with coil overs? I was looking at the kw from tirerack, pricey! For that kind of money ~$2k:
    1. Is there a performance increase in handling e.g. H&R vs. KW coil overs?
    2. Periodic maintenance associated with daily driving coil overs such as KW variant 3?
    3. Would I be throwing away money for a gain of 0.5" in height?
    4. Any phantom noises from others that have KW coil overs or equivalent?
    Any help would be appreciated. I've groomed the forums and found many satisfied with coil overs.
    Thanks!
    Larimer is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Feb 2012
    Novi, MI
    31
    71
    Re: Replace H&R springs with coil overs?
    Go to a real alignment shop that does race cars.
    darkman's Avatar
    Automobile(s): 2005 CTS-V
    Nov 2005
    Spring, Texas
    8,164
    I do not have KWs. Based on the reports over the years of those who have installed them though, the the KWs have a reputation of improving the handling on both street and track. The KWs also have NOT been the subject of complaints about noises in contrast, for example to Ground Control setups that can require some tinkering to get quiet.
    Andringa is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V Blk/Blk
    Nov 2009
    Wisconsin
    33
    785
    If you are only looking for .5", search around a bunch of people have done small adjustments with rubber spacers in the spring perch. H&R tend to sit low in the rear, so people are usually putting the spacers in to just bring the rear up a bit.
    You should be able to get it aligned, just a matter of finding a shop that knows what they are doing.
    philistine's Avatar
    Sep 2011
    821
    Thanks for the replies. I think I'm just gonna take out the H&R springs and go with the KW coil overs. I'm at 68k with stock shocks, so the upgrade fixes the ride height and resets my maintenance for dampeners not to mention some performance added to the mix. I want to get headers and I think I need the extra clearance, I'm scraping over speed bumps as it is now.
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    You will like the KW setup. If you need even more height just order stiffer springs for the kw kit.
    thebigjimsho's Avatar
    Automobile(s): ZIP
    In the barrel of a gun...
    51,885
    I loved my Ground Controls.
    philistine's Avatar
    Sep 2011
    821
    Now to hunt down a deal on the KW variant 3...
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    Make sure you get that SW exhaust installed as close as possible to the body.. 3in pipes are a monster.. install it loose, then jack the exhasut up at the resonator and work your way from the front of the car to the rear impacting the single bolt clamps down.. jack it up till its super close tothe drive shaft.. it will settle a back down.. be ready for a workout if your on jack stands
    philistine and philistine like this.
    etcts-v's Avatar
    etcts-v is offline Cadillac Owners Enthusiast
    Automobile(s): 2004 CTS-V, 423 RWHP / 380 RWTQ
    Nov 2010
    Seattle, Washington,
    35
    577
    As soon as budget allows I'm going the same route, my current setup with H&R springs and stock 60k dampners is not cutting it, to low and every small bump in the road sends me to the chiropractor! I like the KW setup, just have to come up with the cash now!
    philistine's Avatar
    Sep 2011
    821
    Found some KW coilovers on ebay. These are for $2033.29 free shipping. Thought I could find a better deal...no such luck yet.
    http://compare.ebay.com/like/1808226..._lwgsi=y&cbt=y
    Jan 2009
    246
    Search on Google for the part # under 2k shipped
    philistine's Avatar
    Sep 2011
    821
    I'm wondering if the CS rear end swap would get in the way of these pipes. Did you install the CS kit yet?
  16. #14
    philistine's Avatar
    Sep 2011
    821
    Dropped some coin on the kw's. Did the install over the weekend and really took my time - labor of love. Drove it today and I can only parrot what others have said...feels firmly planted! I went from H&R springs to the KW's - night and day difference.
    I know there are other write-ups on the install but I took my time and have about 50 photos from how and where to jack up the car to each complete step of the install. I also projected the adjusted height of the car from interpolating the data from KW. This served as a guideline to minimize the guess work of the ride height. My projections thus far are accurate. I can easily do a write-up and provide a procedure of the install along with calculations of projected height vs. actual - and of course the 4-6 week check-up after springs settle. The biggest PITA was figuring out how and where to jack the car and put on stands - I'm big on safety and found a good compromise.
  17. #15
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    Quote Originally Posted by philistine View Post
    Then do a writeup
  18. Remove Advertisements
