Rev Shift Motor Mounts Install Writeup Tutorial - Page 6
Page 6 of 6 FirstFirst 1 2 3 4 5 6
Results 76 to 89 of 89
Like Tree33Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Rev Shift Motor Mounts Install Writeup Tutorial in Cadillac CTS-V Series Forum - 2004 - 2007; I did this swap almost a year ago. Took me 2.5 hours by myself. I didn't remove any exhaust or ...
  1. #76
    Tom400CFI is offline Cadillac Owners Member
    Automobile(s): '05 CTS-V
    Jul 2009
    Park City, UT
    45
    91
    Re: Rev Shift Motor Mounts Install Writeup Tutorial
    I did this swap almost a year ago. Took me 2.5 hours by myself. I didn't remove any exhaust or the dipstick. What I did that (I think) is different than what others have done is that I disassembled the mount on each side, from the two aluminum brackets, before pulling them all from the car. This made it easy to snake the parts out w/out removing anything extra.
    My "Blues" have been fantastic and we are so much happier with the car since installing them. It turns out that our mounts were blown since we bought the car with only 28k on it. The original mounts were totally torn in half and filled with dirt.
  2. #77
    Naf's Avatar
    Naf
    Naf is offline Cadillac Owners Connoisseur
    Apr 2007
    2,090
    Has anyone tried the red ones yet?
    I have the blue ones and will be installin the thermal shields. I am not looking for teeth shattering vibrations, but a little tickle on the end nose will be fine..
  3. #78
    GDPossehl is offline Cadillac Owners Enthusiast
    Automobile(s): '04 CTS-V
    Feb 2011
    Decatur, GA
    506
    Quote Originally Posted by fre1102 View Post
    I'm in Coral Gables, but the car is at my brother's in Boynton Beach right now--nowhere else to work on it. I'm talking about the mount-to-block 15mm bolts now. I got the other ones off.
    How are you meant to remove the inner-most bolt on the mount-to-frame connection? There's literally no way I could see to get a wrench on the bolt.
    I'm right next door in The Grove, if your car was closer I'd shoot over to have a look. I don't recall having any trouble getting at those bolts. I did most of my work from underneath the car. Is the inner-most bolt the one farthest to the rear of the car? If so I can remember just reaching straight up from underneath.
  4. #79
    fre1102 is offline Cadillac Owners Fanatic
    Automobile(s): None yet
    May 2012
    36
    296
    The one I'm having trouble with is the upper left nut on a stud (if you're sitting facing the driver's wheel). It's pretty well fused on there and I don't have an impact in this ZIP code.
  5. #80
    Jul 2009
    Park City, UT
    45
    91
    Put some heat on it.
  6. #81
    May 2012
    36
    296
    Quote Originally Posted by odla View Post
    Im in Miami also. I didn't do the install. I know of a great place ( or has been so far ) in North Miami. Doesn't look like much but the guy is honest. Has done work to both my cars.
    BTW have you seen the how to videos?
    1390 ne 125st
    33161
    Any chance you've got their phone number?
  7. #82
    odla's Avatar
    odla is offline Cadillac Owners Connoisseur
    Automobile(s): Cadillac platinum 04 & Blk 05 cts-v
    Nov 2006
    miami ,Fl
    2,357
    sent you a pm.
  8. #83
    hawaiianguy is offline Cadillac Owners Member
    Automobile(s): 2004 CTS-V
    Mar 2014
    Ft. Hood, TX
    26
    3
    Are the bolts supposed to be torqued to a specific ft/lb, or just hand tight?
  9. #84
    wiskey is offline Cadillac Owners Member
    Automobile(s): 06 CTS-V
    Dec 2011
    Detroit
    34
    I did the revshift motor mounts this weekend while I was installing some Kooks Long tubes. I went with the blues. The stock mounts looked fine and the engine didn't rock back and forth, even my buddy who is a gm tech said they are fine. When i took them out they were toast, lots of rubber missing and the bolts moved around like a spoon in peanut butter. My car has 110k on the OD and is an '06
    The new mounts are great, in fact my favorite thing I have done so far. They made everything so smooth and compared to my old stock mounts they ride so much better. I barley know the engine is on except when stopped then I notice a tiny shimmer sometimes but nothing that I would complain about. They took care of the vibration i would get at low speeds in reverse which I though was the flywheel letting go.
    I was worried that because these mounts were poly the added vibrations would be bad as this is my DD. Not the case what so ever. Very glad I did.
    Just my 2cents.
  10. #85
    JD03Cobra's Avatar
    JD03Cobra is offline Cadillac Owners Connoisseur
    Automobile(s): 2010 Thunder Gray 6MT
    Mar 2008
    Michigan
    44
    2,122
    ^^ Fantastic! You ready to install mine next? lol
  11. #86
    pato is offline Cadillac Owners Fanatic
    Automobile(s): 2011 CTS-V
    Aug 2011
    186
    Quote Originally Posted by hawaiianguy View Post
    Yes. 37 lb-ft, IIRC.
    Definitely not just hand tight, lol.
  12. #87
    54inches's Avatar
    54inches is offline Cadillac Owners Fanatic
    Automobile(s): 2005 V
    Sep 2007
    Houston, TEXAS
    42
    474
    I just got their cradle bushings and they are SEX!
  13. #88
    JD03Cobra's Avatar
    Mar 2008
    Michigan
    44
    2,122
    The trans mount is settling down a bit. Not as noisy but i still feel plenty of transmission and or drive line. Shifts perfect though.
  14. #89
    ikcts is offline Cadillac Owners Member
    Automobile(s): 04 cts-v
    Jan 2015
    1
    revshift, I have pair of brand new revshift motor mounts (red) hard racing ones. But, since I'm a regular street driver and I use My cts v most for work; I like to know If I can exchange them with the 80a blues one...for soft street driving...please let know .. thank you!
  15. Remove Advertisements
