Another DIY intake (Carbon fiber) Pics! - Page 2
Results 16 to 30 of 32
Like Tree9Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Another DIY intake (Carbon fiber) Pics! in Cadillac CTS-V Series Forum - 2004 - 2007; http://store.airflo.com/90hl40r35.html Here's the link for the elbow. No clearance issues, The silicone hump hose was touching the power steering pulley ...
  1. #16
    danrob0123's Avatar
    danrob0123 is offline Cadillac Owners Fanatic
    Automobile(s): 2004 RAVEN CTS-V
    Oct 2009
    Long Island
    28
    191
    Re: Another DIY intake (Carbon fiber) Pics!
    Here's the link for the elbow. No clearance issues, The silicone hump hose was touching the power steering pulley at one point but after a little adjusting I was able to get it out of the way. This was the only clearance issue as the carbon fiber tube fits in there perfectly. As you can see it doesn't come very close to the radiator support. I did have to cut about an inch off of the carbon fiber tube and also about an inch off of the TB side (4" side) of the elbow.
  2. #17
    odthetruth's Avatar
    odthetruth is offline Moderator
    Automobile(s): 2006 CTS-V
    Feb 2010
    NYC
    4,969
    I assembled my intake from ebay parts, and snatched up this carbon fiber tubing to replace the aluminum tube I had set in the first place...
    Thats how mine originally looked when I was done. I snatched up the elbow I use here from ebay. Cost me $20 on ebay. I pulled it out after that first picture and put my stocks on because I kept throwing lean codes thanks to the intake filter.
    I just now replaced my stock tubing with the carbon fiber tubing exactly like this but with the stock filter.
    Still retains heat, but honestly feels a bit less then the aluminum tube.
    Good find on the carbon tubing.
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
  3. #18
    garrettg is offline Cadillac Owners Fanatic
    Automobile(s): 07 CTS-V
    Jan 2009
    246
    Bought one as well what adapter did you use for the pcv fresh air line?
  5. #19
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    I have a 90 degree 3/8 barb elbow I picked up from Home Depot. Drilled a hole to accomodate it in the big red elbow... then ring clamped it down, and RTV gasketed from the outside so it wouldn't leak any extra air in. Let it dry, etc... Works perfect. I been using the actual tubing for a while with no issues. The only issues I ran into was lean codes with the K&N filter. I thought it was possibly over-oiled at first, but after double and triple checking everything (cleaning MAF, checking filter, etc)... I've come to the realization that it'll need a tune with the intake filter on.
    [2006 CTS-V]
  6. #20
    Jan 2009
    246
    finished up today with same cf ebay tube cut 1 inch off tube
    jaygone7 and jaygone7 like this.
  7. #21
    danrob0123's Avatar
    Oct 2009
    Long Island
    28
    191
    Looks good! The elbows you guys both used look a little longer than mine, if you wanted to you could cut an inch or so off of the elbow (tube side) to expose more of the CF, Just an idea.
  8. #22
    PISNUOFF Guest
    You guys have dirty engine bays (except Danrob0123). Lol
    odthetruth and odthetruth like this.
  9. #23
    odthetruth's Avatar
    Feb 2010
    NYC
    4,969
    Pffft. I know I do. I don't pop the hood really though, so I don't care so much.
    [2006 CTS-V]
  10. #24
    JDB's Avatar
    JDB
    JDB is offline Cadillac Owners Connoisseur
    Automobile(s): '05 Raven/Ebony CTS-V with toys
    Apr 2010
    PA
    1,070
    Quote Originally Posted by garrettg View Post
    Attachment 93469
    Where did you buy the elbow and hump hose? (for comparison sake) thanks.
  11. #25
    PISNUOFF Guest
    siliconeintakes.com. 4" to 3.5" reducing elbow
  12. #26
    jaygone7's Avatar
    jaygone7 is offline Cadillac Owners Member
    Automobile(s): 04 CTS-V1 ls6
    Jul 2012
    27
    38
    what size hump hose???
  13. #27
    jaygone7's Avatar
    Jul 2012
    27
    38
  14. #28
    jaygone7's Avatar
    Jul 2012
    27
    38
    bump
  15. #29
    danrob0123's Avatar
    Oct 2009
    Long Island
    28
    191
    Quote Originally Posted by jaygone7 View Post
    3.5". Mine was tight on the MAF end but it fits
  16. #30
    danrob0123's Avatar
    Oct 2009
    Long Island
    28
    191
    Oh and mine was 3" long
  17. Remove Advertisements
