Sway bar bushings
Page 1 of 2 12 LastLast
Results 1 to 15 of 25
Like Tree5Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Sway bar bushings in Cadillac CTS-V Series Forum - 2004 - 2007; Anyne have any info / tips on swapping them out. They look pretty straight forward. I am replacing them with ...
    6 SPEED Z is offline Cadillac Owners Fanatic
    Automobile(s): 2005 Red Line CTS-V
    Dec 2008
    Dover, Delaware
    278
    Sway bar bushings
    Anyne have any info / tips on swapping them out. They look pretty straight forward. I am replacing them with new stock units, did not think anyone did them in poly.
    Thanks
    Mike
    HAMSTAR is offline Cadillac Owners Enthusiast
    Automobile(s): 2006 CTS-V
    Apr 2012
    Seattle, WA
    731
    Re: Sway bar bushings
    deleted due to idiocy
    Dec 2008
    Dover, Delaware
    278
    Yea I have a clunk. When I did the end links last year, I noticed some play in the bar bushings, I could move the bar up and down in them a little, so figured wtf, easy enough to change and see if it affects anything. And I am at 80k miles or so, so figured wth change them.
    CTSV_510's Avatar
    CTSV_510 is offline Cadillac Owners Connoisseur
    Automobile(s): '06 Z06, '05 CTS-V 453rwhp/434rwtq (sold)
    Jan 2008
    West Chester, PA
    34
    4,455
    It's not hard at all, especially if you're just replacing the bushings and don't need to take the bars out.
    http://cadillacfaq.com/faq/answers/swaybar/index.html
    HAMSTAR and HAMSTAR like this.
    Dec 2008
    Dover, Delaware
    278
    Thx for the info.
    Apr 2012
    Seattle, WA
    731
    Quote Originally Posted by CTSV_510 View Post
    If I understand correctly, you will need to take the sway bar out even if you are just replacing the bushings. You need to take the sway bar to a machine shop to have the bushing pressed out. Is that not correct?
    Dec 2008
    Dover, Delaware
    278
    No the bushing is free by itself, it has a u-shaped clamp around it. The rubber part is separate fron the clamp. And it is split so it slips over the bar. The bushing is not one piece like you are thinking.The end links prob need to be disconnected to work the bar around so you can get the bushind out and back in.
    CTSV_510's Avatar
    Jan 2008
    West Chester, PA
    34
    4,455
    Quote Originally Posted by HAMSTAR View Post
    Not at all. The bushings slide over the bars like a ring slides over a finger. Actually, now that I think about it they may even have a slit in them so you can pull them apart to go around the bars. Either way, you do not need to have anything pressed.
    Apr 2012
    Seattle, WA
    731
    Well, ****. I was thinking of control arm bushings. Move along, nothing to see. Just an idiot (me).
    odthetruth's Avatar
    odthetruth is offline Moderator
    Feb 2010
    NYC
    4,969
    15mm and some grease. Its a 1-2-3 thing. You'd do best to take the wheels off when you do it, but you can probably do 'em with the wheels just turned... although it'll make it harder.
    Get a long breaker bar / decent sized torque bar. They tend to be on there good if you haven't done 'em before. lol
    [2006 CTS-V]
    Bolt ons and Bolt ins, and Bolt underneaths.
    PISNUOFF Guest
    I want to know the results of the replacement. I have Hotchkiss bars but I still would like to know. Please post the results.
    Dec 2008
    Dover, Delaware
    278
    OK, swapped out the bushings.
    Pretty straight forward. I jacked up the front end, pulled both front wheels off, disconnected both end links, and swapped out one side bushing at a time. A deep 15MM socket works good for the aft or back bolt, and a short one for the forward one. Holding the new vs old bushing next to each other you can definately tell the difference, the old one was reamed, stretched out and looked noticiably bigger then the new one. I used a little Krytox lube we use on the Boeing Business Jets we work on at work to lube the inside of the bushing and reassembled.
    Have not driven it yet so no road/clunk report yet.
    Mike
    Apr 2012
    Seattle, WA
    731
    Thanks bro. Looking forward to the clunk report!
  16. #14
    Dec 2008
    Dover, Delaware
    278
    Yea I had other cars in the way last night so no drive yet, tonight I will get it out and clunk check it, let you all know later tonight or tomorrow.
    Mike
  17. #15
    Dec 2008
    Dover, Delaware
    278
    Sorry rain in the area last night so no clunk check, hopefully tonight.
    Mike
  18. Remove Advertisements
