Teaser pic of my current project.. - Page 3
Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Like Tree6Likes
2004-2007 Cadillac CTS-V Performance Mods Discussion, Teaser pic of my current project.. in Cadillac CTS-V Series Forum - 2004 - 2007; Dude this is one awesome build nice work...
  1. #31
    xbladr is offline Cadillac Owners Fanatic
    Dec 2008
    377
    Re: Teaser pic of my current project..
  2. #32
    Oh5V is offline Cadillac Owners Member
    Automobile(s): 1998 STS, CTS-V (sold)
    Apr 2010
    75
    Today I got the scavenger oil pump for the supercharger mounted and all the return lines ran.(too much of a pain to do a gravity feed drain) Instead of barbed fittings and hose clamps which I had, I decided to change over to all -8AN stuff with steel braided line. The return snakes around to the back of the engine and is completely hidden under the engine cover.
    Today I got back my valve cover with the aluminum bung welded in. The oil scavenger pump will pump the oil from the supercharger drain up into there so I wont have to worry about gravity.
    Tomorrow I'll connect the oil feed line(with aftermarket gauge sender in place) and hopefully hook up the air intake(waiting on delivery of the 3.5" 90degree elbow) Then its a matter of attaching the lower rad hose, and connecting the TB coolant line/overflow line. Oh and wire the oil return pump up. Then all IC pipes get reconnected and front Bumper goes on.
  3. #33
    Apr 2010
    75
    Getting closer....
    Radiator shrouds are done
    all I/C piping is connected
    Lower mesh grille has been epoxied in place
    Front bumper ready to be bolted on and attached for good
    Radiator/coolant hoses need to be connected along with vacuum hoses.
    oil pump wiring still needs to be done too
    lower fan mount needs to be fabricated and power steering cooler remounted
  5. #34
    shadybx7's Avatar
    shadybx7 is offline Cadillac Owners Connoisseur
    Automobile(s): 2005 Platinum CTS V-Headers+3in pipes
    Apr 2008
    3,014
    great progress!! nice to see some more jersey Vs
  6. #35
    Apr 2010
    75
    Chased a few gremlins in order to fire it up for the first time... Ignition powered on, but no crank at all.
    The Driver Information Center was throwing air bag codes, a/c codes, theft security system codes, no gauge info, no outside air temp display, etc etc...
    Turned out to be a poor connection in the fuse box that I had taken apart. I went over it all again and solved all those issues.
    The oil scavenger pump will be wired up to the fuel pump trigger but through the new racetronix hotwire kit. Since I don't have the harness yet(coming tomorrow) I just jumped the oil pump trigger wire to the battery as you'll see in the video(uploading now).
    The sound is not as high pitched in person as it comes across in the video.
    All I need to do now are gauges, injectors, and fuel pump, then time for the tune at RPM in Delaware next week.
    I pulled it out of the garage and let it get up to temp to check for leaks and to verify that the fans work and wouldn't overheat. I then washed it since it was filthy from sitting almost 5 months.
  7. #36
    Apr 2010
    75
  8. #37
    V for victory is offline Cadillac Owners Fanatic
    Automobile(s): 2012 CTS-V, 2013 Dodge Durnago R/T
    Mar 2011
    Levittown, PA
    51
    243
    AWESOME !!! YES ALL CAPS, I'M YELLING !!!! THATS AWESOME !
    now what did you use to cover the cross support and engine cover I want that done on my V.
  9. #38
    Apr 2010
    75
    Quote Originally Posted by V for victory View Post
    I didn't cover them with anything, they are the optional OEM carbon fiber pieces. They are both real solid carbon fiber.
  10. #39
    acaringnihilist is offline Cadillac Owners Member
    Automobile(s): 2007 CTS-V
    Nov 2011
    Michigan
    40
    That is awesome. Great work.
  11. #40
    lollygagger8's Avatar
    lollygagger8 is offline Cadillac Owners Connoisseur
    Automobile(s): Platinum 2004 CTS-V
    Apr 2008
    Indiana
    4,913
    GREAT Job getting it all back together.
    I hope that high pitch subsides when you close the hood!
  12. #41
    Dec 2008
    377
    that thing sounds amazing! dude well done
    ps... Lolly i think that sound is from the camera and not being able to handle that frequency
  13. #42
    Apr 2010
    75
    well, project has come to a standstill.....
    headunit is complete junk, i need to buy a new one. it was making no boost, blowing oil, and has prior impeller damage. Its all already off the car.
    I'm setting up the car just so i can drive it in the meantime, and this weekend im ordering a new procharger d1sc which i'll have to remake the bracket for and yank out all the oil supply/return stuff.
    it never ends lol
  14. #43
    NCOGNITO's Avatar
    NCOGNITO is offline Cadillac Owners Fanatic
    Automobile(s): 2004 CTS-V - Black Raven
    Apr 2012
    39
    283
    BUMMER! Sorry to hear the news, the project looked like it was really shaping up :-(
  15. #44
    Dec 2008
    377
    Hang in there when you get the new one in it will be amazing. Good luck man
  16. #45
    I hate my AMG is offline Cadillac Owners Fanatic
    Automobile(s): 04 Black LS6 CTS-V
    Oct 2011
    Northern Jersey !
    25
    153
    Jersey we have some of the nicest V's ! Get that thing boosting ASAP! id love to see this in person where in jersey are you located we should get a small mini V meet going hahha
  17. Remove Advertisements
